Question about Kenmore Dishwashers
I turn the dishwasher on and I hear a hum but no water.
    Master:
  • 414 Answers
Some of the newer kenmore and frigidaire models have a delay start feature. the
dial actually starts the cycle about the 3 o' clock position instead of the 1 o' clock
position. Hope this helps.
Posted on May 28, 2011
Asko 1375 not running right, turn it on hear humming only no water running
It is likely the inlet valve is faulty provided the tap under kitchen sink is open and there is water supply to the dishwasher.
Jan 12, 2013 | Asko 1375 Dishwasher
Dishwasher is not washing
Possibly inlet hose line is blocked with crud from your water source. Please confirm by turning off water under sink, disconnecting hose under dishwasher and, WITH HOSE IN AN OLD MILK BOTTLE, slowly turn on water under sink to verify water flow. If ok, water inlet selenoid is blocked and needs to cleared (with compressed air). Alternatively, input seleniod is burned out and needs to be replaced.
Jan 05, 2012 | Whirlpool Dishwashers
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
When you turn the Dishwasher on all you hear is a hum. No water is entering the machine.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
May 15, 2011 | Kitchen Ranges
I bougt a kenmore 18" dishwasher, the dishwasher
Sounds like the water is either off or a flood safe hose is being used. The valve is energized and water is not flowing in, that is what the humming noise is.
Appliance & Refrigerator Repair
Mar 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher fills with water then hums
Hello & Welcome to FixYa
When the dishwasher fills then it means that the control and the water inlet valve are fine, hum sound itself indicates that the motor is bad and needs replacement. If you hear a hum sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | KitchenAid KUDS50FVSS Builtin Dishwasher
No water getting into the dishwasher
At the bottom of the dishwasher remove the kick panel . Then turn on the dishwasher , and then locate the water inlet valve , it should be on the left hand side with hose going to it . the pipe might be copper or plastic or stainless steel . listen for a humming noise . If you hear a humming noise . there is no water getting to the unit . make sure the hose is not kinked and the water is turned on and clean the screen on the valve . if there is no humming it is bad water valve . ( cleaning the water valve ) remove the incoming water line and remove the screw that holds the valve in . Then remove the 90 degree fitting on the bottom . you will see the screen .
Oct 31, 2009 | Dishwashers
Engine is humming but the water does not make it into the dish washer
Replace the water solenoid valve, but try opening it up first, and seeing if there is any build up inside the valve. This is normal in solenoids just remove the obstruction and water should fill.
Apr 27, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Dishwashers Logo
57 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
