Question about Westinghouse Electric SK-32H570D 32 in. LCD TV/DVD Combo
When I turn the TV on the Westinghouse logo appears, followed in a few seconds by the setup screen and then the screen goes black. I've had this TV for a little over a year and it was working fine until this morning.
  • 27 Answers
One of the inverter transformers could be blown too. You can buy them on e-bay by entering the number from the top of the transformer, It requires soldering. The bad transformer will be 'leaking' or will have burned the circuit board.
The problem I have had is that even after replacing the transformer, the over-current circuit kicks in and the same 'shut-off' thing happens. I replaced all of the blue 5pf 3kv capacitors with 5pf 6kv caps, and still the same problem.
finally, I just removed all of the blue capacitors by the transformers and now it works great!
Unfortunately, this bypasses the over-current protection and the set will not turn off next time a transformer has a melt down. Possible fire hazard.
be careful with this fix.
I would recommend not leaving the set unattended, and if you smell burning, turn it off.
Unfortunately, since the manufacturer was nice enough to shellac or leave a heavy rosin coating on the solder side of the board, it is really hard to test individual components :(
Good Luck!
Posted on Mar 08, 2012
    Sergeant:
  • 247 Answers
Sounds like a simple input issue, the set up screen has popped up because a signal is not being detected by your video ports. I would hit the source button on the manufacture remote control and toggle it to the right input. is it connected to a cable box??/ and if so what type of inputs are going to your tv from the source, eg, hdmi dvi, coax, component ????? and also is there a dvd player or vcr in the mix, if so I would also check the cable from it and even bypassing the dvd or device going directly into your tv can also tell volumes.
Posted on May 28, 2011
Blu ray shows the "Blu ray Disc" Logo on TV screen and then just show a black creen
Hi! and welcome to Fixya!
It looks like your tv is unable to handle the output video resolution from your bluray. The reason why you do not have picture on the tv screen after the bluray disc logo appears.
You can follow the instruction below to set the video resolution on your player to its lowest resolution:
1. Using your bluray remote control, press the following buttons in order... STOP button (press and release) ....HOME button (press and release)....POP UP/MENU button ( press and release )
Note: press the buttons in order with 1 second interval. Make sure tv and bluray are ON when you try this. If first attempt nothing happens, try this again.
2. When the home menu screen appears after doing the above instruction, you can set the video resolution again manually. Follow the instruction:
Using the BD remote control press HOME button > then go to SETUP > select screen settings > then change OUTPUT VIDEO RESOLUTION to Auto > change also 24P OUT to 1080P // set the BD-ROM 24P OUTPUT to Auto
The next time you turn on the bluray player you will have picture again.
Let me know if this works!
Oct 24, 2015 | Sony Televison & Video
My tv when powered on, only show the westinghouse logo and then the screen turn black in about 3/4 seconds
The TV is not receiving a video signal. It is probably the cable you are connecting the tv to the source. If you are using an adapter, don't. Buy a proper cable.
Mar 31, 2014 | Westinghouse 32" Flat Panel LCD HDTV
4h b0700 071
Read my answer to your first post.
Mar 31, 2014 | Westinghouse Televison & Video
Screen size and resolution keeps changing while I work.
some tv devices are set by default to auto adjusting, look in tv's setup and adjust the resolution manually.
Feb 23, 2013 | Toshiba Computers & Internet
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
Tv screen goes black ater 10 seconds
there could be several things causing this, most often it's a defective inverter, or a bad CCFL lamp. You could also have a problem with 24vdc output from the power supply, or "backlight on circuit from the main board. Get a proper diagnoses.
Sep 08, 2012 | Westinghouse TX-47F430S 47 in. LCD TV
Screen go back to black after the westinghouse logo displays.
Westinghouse? A model number might help me help you---does sound remain or never make it on?
Mar 14, 2012 | Televison & Video
When I turn it on, the westinghouse logo appears, then the signal appear for one or two seconds and the screen goes black. I openned it and i do no see anything wrong (visual examination) with the...
Ur tv still have audio sound after the tv LCD screen panel gose blank?Yes,than the tv long LCD inverter board it is shorted and dead,must be replaced,mean not thing visually examination is good or no burn mark on the board,because this it not a power supply board sections dosen't draw much heat to causes any visual damages.
Aug 11, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
My westinghouse flat screen tv - i turn power on picture comes on for a few seconds and goes black - sound still works - any suggestions?
The tv have 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards for the replacement.
Oct 07, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse Electric SK-32H570D 32 in. LCD TV/DVD Combo Logo
343 people viewed this question
Top Westinghouse Electric Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Neil Frazier
Neil Frazier
Level 1 Expert
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
