Question about Mtd Garden Tiller (Mtd)
Mtd 5 hp front tine tiller will not run only for a minute took carb apart and found foreign matter in tank cleaned tank now need diagram how to put back togerther
  • 10865 Answers
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Posted on Feb 27, 2009
SOURCE: broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Posted on May 13, 2009
01fordeb
  • 1033 Answers
SOURCE: Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Posted on Mar 24, 2010
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
SOURCE: tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Posted on Apr 16, 2011
How do I adjust the carburetor on an Ariens 5020 tiller, model #901016, with a 5 HP Tecumseh engine?
close the needle valve completely, then back it off 1.5 turns. Adjust from there for most efficient fuel usage.
May 04, 2015 | Ariens Rear Tine Tiller 17 901028
Troy bilt troubleshooting tiller
sounds like not enough vacum to draw fuel .faulty diaphram pump. gas cap should have a breather assembly to allow air to enter gas tank and prevent a vacum lock as well
Jun 29, 2014 | Mtd Bronco Rear Tine Tiller
2 year old gas in tank. tiller won't stay running
When you drained the gas from the gas tank did you also take the carb apart and clean it. There should be a bowl that the fuel line from the gas tank goes to. There is a float in that bowl that has to go up and down to regulate how much gas goes into the engine. You may have a build up of varnish from old gas on the piece that the float moves up and down. Also there should be an idle jet that you screw in and out to adjust the idle. That also could be junked up.
Apr 18, 2013 | Ariens 902032 - 12"/22"/24" 6HP/169cc...
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Mar 20, 2011 | Mtd Garden
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
Need to know how to rebuild the carb on a 3.0 hp
The carb sounds like a vacu-jet, very easy to rebuild. Remove it from the tank but be careful not to damage the siphon tube. Then make sure to check for foreign matter in the tank (big problem with this system), clean and flush it. The idle screw is easy, the other is set by going from idle to full throttle quickly and adjusting it just so it doesn't stumble
Apr 24, 2010 | Craftsman Gas Mini - Tiller/Edger
I have a 2003 huskee rear tine 5.0 when i spray starting fluid in it's runs 4 a few seconds then dies. I have cleaned the carb and the gas tank and line, I still seems that it is not getting fuel
Did you clean out all of the tiny holes in the main jet of the carburetor? I assume you also put fresh fuel in it as well. One other thing, a compression leak (loose spark plug, bad head gasket) can make it act like it's starving for fuel. Good luck. I'd still place my bet on the carb having one or two holes plugged in the main jet.
Mar 17, 2010 | Mtd Products Yard Machines 158CC Tiller
Broken clutch cable connector, MTD Tiller
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
5 hp Briggs and stratton wont run on a MTD tiller.
I had the same problem a few years back. Check the rubber elbow coming from the gas tank to the carb, it's probably cracked and sucking air instead of fuel from the tank.
Nov 30, 2008 | Garden
Mtd Garden Tiller (Mtd) Logo
69 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
