Question about ASUS Computers & Internet
I have a Asus P8H61-M motherboard.I have made the required on-board connections (power, audio etc), however I cannot figure out how & where to connect the optical (DVD) drive. There doesn't appear to be any free connections to where I would connect the optical drive. ANy ideas of suggestions?
  • ASUS Master
  • 5,160 Answers
What type of connection does your optical drive have? If it is a SATA drive, use one of the four SATA ports.
If you have an IDE drive, this motherboard doesn't have an IDE connection on board. If you want to use this drive, you need an IDE to SATA converter, for example: http://www.newegg.com/Product/Product.aspx?Item=N82E16812232004&cm_re=ide_to_sata_converter-_-12-232-004-_-Product . This is for internal use. You could also get a PCI or PCIe IDE controller. Some PCIe examples are here: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=ide+pci+express . These will work if you still have one of the PCIe slots available. (Some video cards may block the slots.)
There are also USB to IDE dongles or 5.25" enclosures that will work (best for non-slim optical drives).
I hope this helps.
Posted on May 28, 2011
Need Motherboard drivers for Asus N13219
n13219 is actually the asus P8H61 motherboard
Dec 25, 2016 | ASUS Computers & Internet
One ram slot not working
Check below ASUS link if it solves you problem. You can also contact ASUS support. If your problem persists, you have no option other than replacing the board.
ASUSTeK Computer Inc Support Troubleshooting P8H61 LX
Feb 18, 2014 | ASUS P8H61-M LX LGA1155/ Intel H61B3/...
Deep sleep mode
Go in the control panel find power options and disable or adjust the sleep mode there.
Terry
Oct 19, 2013 | NA ASUS P8H61-M LX3 R2.0 Intel LGA1155...
P8h61-m le r2.0 won't see sata devices/no bootable device found
I guess u try'd this......?
Chang the cable of hard drive and check the boot priority.....
Feb 15, 2013 | asus-tek Asus Motherboard P8H61-M LE/CSM...
I have a 094225 log.lniis which is lost. How do I fix?
There are several solutions on the ASUS forum.
http://vip.asus.com/forum/view.aspx?id=20090831230304296&board_id=1&model=M4A78%20PLUS&SLanguage=en-us
Aug 25, 2012 | ASUS Computer International Asus P8H61-M...
Do I need to update my bios
Install the latest version is best...You can check it from this link....
http://www.asus.com/Motherboards/Intel_Socket_1155/P8H61M/#download
or
http://www.downloadsource.net/1760468/ASUS-P8H61-M-LE-BIOS/
best of luck!!!
Mar 07, 2012 | ASUS P8H61M Intel H61 TX Motherboard
Will a asus P4533-E motherboard handle a 550w atx power supply without ruining the board?
Yes, the power supply is set to send only the required voltage to the motherboard. The reason you want a large power supply is to handle all the other power hogs (video card, hdd, sound cards, fans, dvdroms, etc...)
Nov 05, 2009 | ASUS P4B533 Motherboard
Front audio in casing
The front panel audio for this board is labelled FP_AUDIO and is on the bottom left hand side of the board. See page 39 of the following; http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5PE-VM/e2609_p5pe-vm.pdf They're all labelled correctly. In your case, L-out - Mic2_L, L-ret - Mic2_R etc
May 29, 2008 | ASUS P5PE-VM Motherboard
ASUS KBN-E MOTHER BOARD 754 processor 512mb ram
Try plugging the drives into another computer to see if they actually work, ie read discs etc if they do then try swapping the power supply out of your computer.. if this doesn't work then I would say your motherboard is dead. Good luck
Jun 02, 2007 | ASUS K8N4-E Deluxe Motherboard
Computers & Internet Logo
433 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
