Question about KitchenAid Dishwashers
Repairman says it is getting no power. The circuit is fine. Could the box inside the dishwasher need to be replaced. He said he isn't an electrician.
    Master:
  • 414 Answers
Sometimes the wire nuts come loose inside the connection box due to vibration. I have
also seen them burn through (when aluminum wire is connected to the dishwasher).
The power to the circuit should be shut off at the breaker panel and checked with
a "Non Contact voltage detector" before removing cover to inspect wire connections
in the connection box. The non contact detector is sold at many big box home
improvement stores for around 12 dollars. I recommend it since many breakers are not
marked at the panel or incorrectly marked, and the wiring can contact the chassis if
the wire nuts are burnt through. Check the detector at a working outlet prior to using.
Hope this helps.
Posted on May 28, 2011
Door switch
Posted on Dec 02, 2011
Wont start
test this steps and fix it. GOd bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#1#ixzz2a26HeZcQ
Jul 24, 2013 | Dishwashers
Samsung dishwasher wont run; delicate cycle light blinking
see this causes and fix it. God bless you
2. Door switch
3. Timer
4. Selector switch
5( test the main board can be faulty and replace.
Oct 02, 2012 | Samsung DMT400RHS Dishwashers : Built in...
The power went out and when the power was restored the dishwasher did not come back on,whats wrong?
the surge could have fried the circuit board in the dishwasher or maybe the house circuit it's hooked into. maybe first check all of your breakers in your breaker box just to be sure one of them isn't tripped
Jul 15, 2012 | Amana ADB1600AWW Builtin Dishwasher
No power
Hello
Plug the Siemens dishwasher into a working electrical outlet if nothing on the dishwasher is operating. Check the household circuit breaker or fuse and reset or replace as needed.
Push the door closed fully if the dishwasher has power but isn't starting. The unit will not operate if the door is open.
Sep 11, 2011 | Siemens 24 in. SL34A006UC Built-in...
Hello. My Bosch dishwasher just isn't turning on again. It was working fine and now I cant get anything to turn on. Thank you
Make sure you have power to the machine. Plug in something you know works into the same power point as the dishwasher. If it works, then you will know the dishwasher has failed. If it doesnt, then check your meter box, switch, RCD etc.
Jul 26, 2011 | Bosch Dishwashers
My kenmore Elite stopped working after my daughter open the door during a cycle. There seems to be no power. Circuit breaker is fine. Any thoughts? Thanks
Mar 28, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Led wont light up. no power to dishwasher
Measure for 115 volts AC at the junction box behind the front lower panel where the incoming power connects to the washer wiring. If ok, you will need a wiring diagram of the washer to go further.
Aug 17, 2009 | Maytag MDB9600A Jetclean II Built-in...
No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
2. Door switch
3. Timer
4. Selector switch
Jul 13, 2009 | Maytag MDB7100AWB Dishwasher
Will not start. Checked pwr to the plug. Is there a reset button? It worked just fine yesterday. Door latch is clean and tight.
2. Door switch
3. Timer
4. Selector switch
Jun 16, 2009 | Maytag MDB6000 Dishwasher
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
May 31, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Dishwashers Logo
201 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
