Question about Garden
Briggs 19hp intek v twin surging at idle not much better at full throttle. totally cleaned carb,new plugs with good spark, new fuel filter and pump works fine. if throttled up and down a few times it will sometimes straighten out and run excellent for a few minutes then go back to same problem. still the carb, or governor, or oil pressure problem?
  • 608 Answers
Hi, probably still the carby as running lean is the cause of your problem. Also check the valve clearances as a tight inlet valve can give similar symptoms. Hope this helps, regards Phil.
Posted on May 28, 2011
Engine is surging when in idle
Sounds like the low speed idle circuit is clogged or the inlet needle tip is clogged in the carb. About the only way to clean these is disassembly.
May 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs 20 hp intek , it run about 15 or 20 minutes and shuts down. i've cleaned the carb replaced filter and fuel line and replaced both coils . what is making my filter run dry?
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
My Sears riding mower chokes itself out after warmed up,
Careful with the high octane.. That can burn a hole in the piston..
It might be fludding.. At the bottom of the carb should be a bowl.. One bolt at the bottom.. Take it off and clean it.. Spray some carb cleaner up in there where the float is..
If that dont do it --
Maybe the float is bad & taking in fluid..
If it has sat for long piriods of time - the carb might need to be cleaned & rebuilt..
When gass sits in there for a long time it shalacks and wont work correctly..
Pop off the carb & take to your local small eng shop. Shouldnt cost to much..
Jul 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Honda IZY engine hunts. I mean the speed pulses rhythmically!
Just adjust the idle speed control/Fuel air screw located pointing downward on the bowl of the carb,Just start the engine,idle up high and turn the screw until it levels out and runs smooth.
May 31, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
