Question about Troy Bilt 5.5hp Self Propelled Mower
I have a TroyBilt series 560 self propelled mower with a Honda engine. The other day I was half finished with the lawn, stopped for a minute, and went to start the mower put my starter string was still pulled all the way out. It never did return like it always had. Do I need a new return spring? I am trying to find out what part(s) I need to fix it and how to change it out. Please help. Thanks.
  • 252 Answers
Hi there
csimonis
it is quite likly that you could need a new pulley and spring
but remove the cover and the starter assy 1st and check that the pawls have not stayed out or jammed , then try winding the spring and pulley up in the direction that the cord is moving when you pull the starter cord - check that end of the spring is still engaged onto the pulley , but if no tension is noted broken spring indicated
sometimes a replacement starter assy is quicker , cheaper
your local mower shop may have a spring & or pawls or starter assy for your model
but just in case get the model codes & numbers off the white tag from your mower
and check out this site for parts
www.ereplacementparts.com
go to troybilt
then select troybilt mower parts
then find your model from the list
then find starter assembly
parts can be ordered on line
cheers paul46
hope it helps
Posted on May 29, 2011
Self propelled lawn mower makes whinning noise
disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
Jul 19, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
I have a Lawn Boy silver series self propelled mower, model number 10324-8902967 that leaks fuel from the exhaust under the mower deck after I have finished mowing and turned the engine off. I will drain...
sounds like the needle valve is not seating some have a rubber tip on needle some have it in the seat but the fuel we now have rot the rubber never store with fuel if possible
Apr 02, 2012 | Toro Lawn Boy Self Propelled CARB Walk...
I have a troybilt xp, and the self propel fontion
Does the drive shaft going to the wheels turn at all?
If it doesnt you may have a unsecured pulley on the engine.
If the shaft does turn when you engage the tranny your next stop is taking the wheels off and checking the wheel clutches. Sometimes called sprag clutches. They are probably both stuck in the unlocked position. You need to clean them up by removing all the greasy material covering them and putting them back together with just a few drops of light oil.
I hope this helps. Good luck and be careful!
Jul 28, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Where do we find the honda engine model number on our Troybilt lawn mower?
a small flat surface...usually near the governor arm...the letter/number combination is "dot" stamped into the aluminum and kinda small....there will be a 4 letters and 7 numbers in a row...thats serial number...right above the 4 letters is 3 or 4 more, know as orientation numbers, that identifies usage...
Apr 18, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My Troybilt starts, idles, then stops. What is
1st thing to try is clean and rebuild carb(easy job) ...good luck
Apr 07, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Need help with belt on Troybilt self propelled push mower
Try removing the pulley in order to put the belt back on.
Jim
May 29, 2009 | Troy Garden
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Troy Bilt 5.5hp Self Propelled Mower Logo
407 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
