Question about Panasonic Heating & Cooling
Hi My CS-E12GFEW heat pump is coming up with fault F91 can you please tell me what the problem is ? Cheers Don
2 Suggested Answers
tatunka
  • 85 Answers
SOURCE: Hi, my Panasonic CS-E12HKR air
http://www.aircon.ru/pbc_download/files/f1147680661.pdf its about the memory norefregerant. look at page 47 for error codes
Posted on Nov 14, 2008
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
My clean light is blinking on my DU1030XTX dishwasher. What is the procedure to clear this code? Thank you very much Don Bilger
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 14, 2011 | Whirlpool DU1030XTXS Dishwasher
Whirlpool dishwasher ''clean'' light is blinking. The ''cancel'' button does not reset the cycle. We don't know how to wash/dry our dishes. We tried the diagnostics but...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 09, 2011 | Dishwashers
MDB6160AWW - flashing lights after hitting the normal cycle: Clean and Heated Dry buttons flash. What is this code telling me? Keith
Hi
These blinking lights indicates an issue with heater circuit, door switch or wash pump. Please reset the power to the dishwasher and after, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Jan 18, 2011 | Maytag 24 in. MDB6100A Built-in Dishwasher
Hi, I recently got my 2005 Audi A4 2.0 TDI serviced by an AUDI garage. They replaced the timing belt and water pump as well. After I left the garage i realised my heating wasnt working correctly....
i would get a water pump from the dealer and install it, In some cases i found that after market water pumps don't have the same clearance between the pump housing and the propeller.this causes less water flow.
Nov 20, 2010 | Audi A4 Cars & Trucks
Dishwasher prog light is flashing and pump is running nothing els
ok, just a few minutes after posting this as a fault, I have opened the covers, the machine has a leak, the undertray has a sensor which has detected this, flashing light (prog 45 degC wash) flashing is a code to indicate leak sensor active.
Other prog lights flashing indicate a different fault, the following details each... this is a cut/paste from another forum site, copied without permission....
jawa592rc_a04.gif on 6th Feb 2008
Cannot guarantee 100%accurate but you all might like what the flashing fault codes actually refer to, note what follows are pointers to what bit has gone wrong only. You should have the programmes running left to right: led1=intensive,led2=normal,led3=eco,led4=fast,led5=prewash,led6=delicate wash.ok so when this heap of western european tosh goes wrong one or two lights will flash this is what they mean:led3=m/ch has o/flowed water . ie the base underneath has sensed a leak.4=i/let h2o valve u/s or slow fill.5=thermister(electronic thermostat) is u/s or more likely the pcb .6=timeout heating which means the thermister senser between the door halves has become faulty or detached.3+4=no pump out,slow pump out,pcb u/s,blockage.4+5=tap off i/let valve.3+5=wash motor not coming on -seized,winding o/cic.but can also mean mesh plte filter badly blocked.1+4software fault with pcb.4+6=heating cic u/s (usually the heater tube )but can be the heater relay on pcb.3+4=pcb u/s.I don`t except any responsiblity for this being spot on or near spot on!! hope this helps someone.Try NOT to electrocute yourselves please!! If your not at all confident walk away and get "someone" who knows what they are doing.Cheers. jawa592
Jan 21, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Heating & Cooling Logo
67 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
