Question about GPS
Chrysler Voyager came back from some minor MOT fixes. Heating fan inside car is running continuously with no speed control
  • deanfurby May 28, 2011
    Thanks. Too late to look now but will do tomorrow.
  • deanfurby May 31, 2011
    Just for your info it was a burnt out rheostat motor behind the control knob. Sorted now.
    Thanks.
    President:
  • 2,047 Answers
Usually when the fan inside starts to run continuously with no speed control it usually is ? sign that the controller fuse or the control switch is burnt. This could be as a result of a number of factors. But generally you need the control switch or fuse whichever is affected replaced. Although you might also want the car wiring system checked to avoid further occurences. The controller could be located in ? variety of places but mostly it is behind the glove compartment. Feel free to request further assistance. Hope this solution has been helpful?
Posted on May 28, 2011
  • Rockme
    Rockme May 28, 2011
    Ok. Let me know what you find out tomorrow.
How do I fix cooling fans that run when car is off
Replace the fan relays. The Radiator Cooling Fan Motor Relay is located: Under hood, driver side, front side of strut tower, mounted in relay panel
Application:
High speed The Radiator Cooling Fan Motor Relay is located: Under hood, driver side, front side of strut tower, mounted in relay panel
Application:
Low speed,here's a new part.
http://www.autozone.com/cooling-heating-and-climate-control/relay-radiator-cooling-fan-motor/duralast-relay-radiator-cooling-fan-motor/plymouth/voyager-2wd/1996/6-cylinders-3-3-0l-mfi/412240_0_0
Sep 22, 2015 | 1996 Plymouth Voyager
2000 chrysler grand voyager over heating when ac is on changed belt and tensioner pulley
YOUR FAN FOR THE AC IS NOT WORKING THE FAN HAVE TWO SPEED 1 FOR NORMAL COOLING AND THE OTHER FOR YOUR AC CHECK AC FAN RELAY IS THAT IS GOOD CHECK FAN MOTOR AND ALSO CHECK CONNECTION ON FAN MOTOR
Sep 24, 2012 | 2000 Chrysler Grand Voyager
Chrysler grand voyager 3.3 2003 front blower reset
Is your A/C off? Make sure it is and try it-good luck.
Jul 09, 2012 | 2003 Chrysler Voyager
1999 grand voyager IS overheating. Randomly, it seems. Short trips, and quickly. AND longer trips. Then, sometimes, it will cool down without further intervention from me. It SEEMS the fans don't come...
Engine quickly overheating is often caused by a stuck closed thermostat. However, in your case since the fans don't come on, the most likely culprit is a bad fan speed controller. These are variable speed fans controlled by the speed controller. They fail when rust forms on the mounting/cooling area where the controller is mounted. This is an electronic device that has a heatsink on the back. When rust forms it can't dissipate heat and that burns out the controller. See the post below for more information on how to replace it.
Car overheats Chrysler Vehicles Ricks Free Auto Repair Advice
Jun 26, 2017 | Chrysler Voyager Cars & Trucks
My fan speed on heating is on fast wont turn down, change relay no good still the same ? help cheers adam.
exterior or interior "fan"
the most common for the interior is a defective blower motor resistor
most common for the exterior is a defective temp sensor or bogus A/C input to the PCM
Jun 03, 2010 | 2000 Chrysler Grand Voyager
My 2001 Voyager blower fan only runs on high.
This is 100% the Blower (Fan) Motor Resistor located near the Blower Motor.
This is a very common problem with Chyrsler, Dodge, Plymouth. The key symptom is the Fan only working on High.
This is very easy to access and replace.
Let me know if this helped....
May 11, 2010 | 1999 Chrysler Sebring
Hi i have a chrysler Grand voyager 2005, the heating started not switch on and then not switch off. there is 12v accross the input of the heating assembly and the controller seems to be functioning...
there is a balast resister or what everone call it blower motor resister these go bad so you can lose your speeds on your blower motor the resister is in the blower box on the back side replace it and your good to go
Mar 09, 2010 | 2000 Chrysler Grand Voyager
I HAVE A 1,9 LITRE CHRYSLER VOYAGER LE PETROL ENGINE. THE FAN FOR COOLING OR HEATING INSIDE THE CAR DOES NOT COME ON. PREVIOUSLY IT WAS CONSTANTLY ON ONLY ON HIGH SPEED AND IT WOULD TURN OFF IF I CHANGED...
Your problem isn't rare; the loss of speeds other than the highest is caused by the failure of a tapped resistor. Selecting the speed chooses the appropriate tap. When the resistor fails, the high speed setting is unaffected since it does not use a tap on the failed resistor.
Sometimes this part is located on the firewall, sometimes close to the fan assembly. It isn't expensive but may be less than fun to replace if it is under the dashboard.
Jul 07, 2009 | 2001 Chrysler Voyager
Chrysler Voyager Diesel W reg - creaking noise over speed bumps
Lower Control arm Bushings, I have Sprayed them down with PB Blaster and they *******
I Know its a Unconventional fix but it worked on mine
Jan 13, 2009 | 2003 Chrysler Voyager
Heater fan continues to run when heating system turned off.
Your Heater Power control module is bad I just had the same problem you can find it right behind the glove box it is mounted in the heater duct very easy to fix 2 screws and it is out and cost is about 150.00 at the dealer it is a dealer only part.
Dec 29, 2008 | 1996 Chrysler Town & Country
GPS Logo
13 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
