Question about Microwave Ovens
I have a Kenmore microwave model 721 62463201. When I try to use it an intermittent loud buzzing noise with "sparks" emit from behind the silver panel inside. Sometimes times there is a burning smell afterward. It helps to cover food with a plastic cover or to turn it off and on again.
MicrowaveSvc
  • 9047 Answers
SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
breddi2
  • 126 Answers
SOURCE: plastic melted inside oven, dripping from ceiling Kenmore 721
The round peice in top of unit is a cover for the stirrer wich moves waves around for even cooking. The reason for it melting is almost certainly there is not enough paint in cavity and waves are shorting out to metal.CALL the manufacturer and depending on age of unit they may replace it free
Posted on Apr 22, 2009
SOURCE: Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Posted on May 01, 2009
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
heatman101
  • 43501 Answers
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
LOUD BUZZING NOISE AND THE ANSWER I RECEIVED WAS FOR A DIFFERENT MODEL. CAN I FIX IT MYSELF?
If the loud buzzing noise is present when cooking food, the magnetron is the likely cause, some models are louder than others. But if the buzzing noise is there without the microwave running it should be checked. No! this something that should be checked by a professional for safety.
Mar 17, 2012 | GE Monogram ZEM200SF Microwave Oven
My microwave is making a loud buzzing sound. Inside the microwave, on the upper right side, is a square area with holes in it. It sounds like the buzzing is coming from behind those holes. Also, after...
THe buzzing noise is most likely coming from the magneton. The magnetron is the main component of the unit (it generates the microwaves). Replaceing it can be very expensive. You may be better off getting a new oven. Prices for new microwave ovens have dropped significantly.
Jun 12, 2011 | Microwave Ovens
My nanny told me my 63252301 microwave can't heat up water. I tried it and once I pessed teh "on" button, the light is on, however, there were a few loud spark noise came out. I pressed the...
Yup the thing is fried...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
May 10, 2011 | Kenmore 63252 Microwave Oven
Microwave makes a loud buzzing noise and emits a burning plastic smell
This indicates the magnetron has failed, buzzing sound and odor are classic symptoms. It is cheaper to replace than have it repaired.
Apr 03, 2011 | Kenmore Microwave Ovens
Kenmore microwave Model No. 721.62463201 runs but does not heat and has a terrificately loud buzz. All lights displays are normal
Hello there:
There's no heat, but it buzzes loudly When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. I recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
And if you have your warranty for this you can use it to ok
Hope this helps best regards mike
Nov 19, 2010 | Kenmore Microwave Ovens
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
