Question about Poulan Pro " Pro" Self Propelled Mower
What kind of fuel do i use in my PoulalnPro600 mower. Is it a 4 cyle?do I use unleaded gas. Not mixed with oil?
  • 608 Answers
If it has dipstick it is a four cycle and you are correct. Hope this helps, regards Phil.
Posted on May 28, 2011
What kind of gas does a 2007 carb/US Weedeater take
87 or higher octane unleaded gasoline mixed 2 cycle engine oil at 40:1.
There is multi-mix engine oil produces a mix that can be used in any 2 cycle that needs 50:1 up to 16:1 oil mix. Makes it much simpler to have container of 2 fuel than several containers going bad.
Nov 10, 2014 | Garden
What kind of gas to used on lawn mower 55 158 cc craftman
Ori Hi, most lawnmowers use regular unleaded petrol now. If you have somewhere that oil goes into your mower then it will be normal unleaded but if on the fuel cap it has an oil can picture you need to mix it with two stroke oil.
Sep 07, 2013 | Craftsman 55 Torque 158cc 22" Push Lawn...
My neighbor has a Honda Yard-Man GCV160 lawn mower. She says it takes an oil and gas mix for the gas tank, but it also has a seperate tank for oil only. What fuel powers it?
Hi, it uses unleaded fuel with no oil. It will need the sparkplug cleaning if they have been mixing oil with the fuel. Hope this helps, regards Phil.
Jul 12, 2011 | Garden
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I just purchased a poulan lawn mower at Kents. Have not used yet. Can you add unleaded gas to the poulan lawn mower/do you have to mix the gas?
You do not mix gas in a 4 cycle engine. You have to mix gas and oil for a 2 cycle engine, such as in a weed whacker, chainsaw, or leaf blower. I do not know of any 2 cycle Poulan mowers (or any other brands for that matter). Unleaded gas is all you can buy in the United States and all current mowers will run on it, although they really don't like that new ethanol additive. If your mower is new then it should have come with an owner's manual which will explain what to do, as well. Hope this answers your question.
James
May 22, 2011 | Poulan "Poulan" Push Mower
What is the gas oil mixture for this product
If this is a 4 cycle engine you do not mix the gas and oil. The engine oil is in the crankcase just like your car. Hope this helps, Happy New Year.
Dec 29, 2010 | Craftsman 4 Cycle Blower/Vac
What type of oil and gasoline do you nee d to run Craftsman 6.5 lawn mower?
generally all 4-cycle lawn mower engines are tuned to use regular unleaded gas ,(I personally use mid or high grade unleaded)....and for engine oil use strait 30 WT engine oil...... I often put a dash of fuel system cleaner in each gallon of lawn mower gas,it is not absolutely neccessary but seems to help moisture stay out of gas..(DO NOT USE HEET or other methenol based fuel additives for this can cause overheating or scoring of piston and cylinder...but rather use a petroleum based additive,this allows the small amounts of moisture in fuel to pass through the carbeurator without clogging filters or fuel system for smoother running)..also...if you put lawn mower up for winter it is always helpful to use a fuel stabilizer such as "STABIL" or other such products (follow directions for use) and be sure to change the crank case oil in the spring before using....this will give you much longer life from your lawn mower...
Keep air filter clean!!!..... Happy mowing!!!....so, the answer?...regular unleaded and 30wt engine oil...if you would like..they have special engine oil for 4-stroke engines at most hardware and walmarts n such...but is just expensive 30wt oil... Enjoy your day,Todd
Nov 23, 2010 | Garden
Craftsman SnowBlower
The term "Unleaded gas only" refers to the type of gasoline to be used. You would use "Unleaded gasoline" instead of "Leaded gasoline". Yes, you will mix oil with the gas normally at a ration of 50 to 1. (1 pint of oil to 6 gallons of "Unleaded Gasoline"). If you do not put oil into your gasoline, you will burn your engine up due to lack of oil. I hope this helped, Good Luck Please rate me, Thanks
Dec 25, 2009 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Poulan Pro " Pro" Self Propelled Mower Logo
54 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
