Samsung srs type no: oz32z30 switches itself off randomly. can switch back on straightaway, anyone any ideas. Thanks
SOURCE: A1000 not switching on
When you have the player stop working and the 'spinning disk' appears, do not bother pressing the reset button-this only switches the unit off. Try giving the unit a sharp shock by dropping it on a carpeted floor from no more than 9-12 inches or holding the unit in your hand and hitting your leg, again with a sharp hit. What ever is skipping in the unit stops and normal operation is resumed. Try not to break your unit by dropping it or hitting it with too much force!
Posted on May 24, 2007
  • 15 Answers
SOURCE: Loewe Aconda 9381 HD/DR+ Will not switch
Could be loss of voltage on secondary or problem on Power supply. Check 4/5 (depnding on chassis) wickman fuses on secondary if none are o/c then replace power supply components with Kit from Loewe. Part number 90415.900.
Should take tv engineer about 1 hour (max) to replace parts form kit.
Posted on Jan 25, 2008
sully_HITMAN
SOURCE: I am the owner of
Your tv must be getting overheaten unplug it from the wall and leave for a day or so then try it!
Posted on Aug 17, 2008
SOURCE: Samsung sgh-u600 - display problem
Mine is also like this, but I now live in Spain. Will I still be able to take it back to the store when I am next in UK ( still within 12 months of buying it) or will they say they wont replace it, cos I have a Spanish SIM card in it now?
Thanks in advance
Ang
Posted on Nov 03, 2008
SOURCE: MY SAMSUNG D880 KEEPS REBOOTING
check did you have memory card "bigger than 1 gb" installed
than remove memory cards,sim cards too
after removing its - start phone and perform full reset with code.
dialing *2767*3855#
but in your phone it will look like *2767*---- after clicking # phone will start full reset
after that return your cards in phone and start using it as new one.
Posted on Oct 02, 2009
Samsung projection TV turning off by itself.
trip switch in back it should be a blue button in the back of tv put tape over trip switch that might work it worked for me
Dec 21, 2015 | Samsung Televison & Video
TV just shuts off randomly. Any idea what the problem might be?
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself
Apr 09, 2015 | Samsung Televison & Video
What cause the airbag light on my instrument cluster to come on randomly then go off while driving down the road?
Check the under seat connector for the SRS system. These can corrode and cause intermittent connection. I would clean it, make sure the airbag fuse is disconnected! !!
Feb 11, 2015 | 1999 Chevrolet Blazer
1991 mercury grand marquis, the horn started honking by itself and won't shut off, I had to disconnect the horn wires. what could cause this?
The switch is behind the air bag. You can disconnect eh negative battery cable for a few hours, then pull the SRS fuse, then remove on the back of the steering wheel, remove the screws and the SRS bag, then check the horn switch and wires. The switch or the spring could be bad.
Mar 19, 2010 | Mercury Marquis Cars & Trucks
Randomly switching off and coming back on by itself.
power supply board may be failing or the power button may be sticking. If it is a Samsung, it is the power supply.
Nov 17, 2009 | Televison & Video
Samsung Plasma PS42Q96HD keeps switching itself off - then sounds like trying to switch itself back on Anyone help?
Replaced swolen capacitors on power board would be first thing. see long thin boards up side. are any of the ics pitted in the center. If so change that board also(buffer boards)
Aug 31, 2009 | Samsung Televison & Video
96 honda accord airbag module......
does the srs light come on and go off at random times and sometimes stay on if that is so check the srs switch under your seat it try moving round in the seat applying weight in diff locations and see if it goes off and on if so then you might need to replace that switch
Mar 05, 2009 | 1999 Honda Accord
Switch starts switching back and forth between computers itself
There are no firmware updates for the GCS62 also the KVM appears to not have a firmware upgrade port. If the KVM is auto-switching have you tried hitting the ESC key or Space Bar? That should stop the auto switching.
Feb 12, 2009 | IOGear MiniView GCS62 2-port KVM Switch
My Samsung HLP6163 tuns off randomly all evening
if you are able to simply turn it back on, then the problem is probably the lamp door cover switch. unplug the set, remove the lampdoor cover. the switch will be in the lower left of the opening. put the door back on while making sure that the switch lever goes down NOT UP. some of these sets came through with the switch up. it works for a while but then the little arm starts to warp and it causes your problem
Dec 14, 2008 | Samsung HLP6163W 61" Rear Projection...
My phone keeps switching itself off
my phone just keeps switching itself off, can anyone advise me on what the issue might be
Nov 11, 2008 | Samsung SGH-D900 Cellular Phone
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
