Question about Sharp 27N-S100 27" TV
We have a black screen with no picure, but dvd's have picture and so does close caption writing. Any ideas????
    Sergeant:
  • 247 Answers
Sounds like its either your cable service or the cable being used to connect your cable box to your TV. The cable of course is my first suspect but on your tv how are you connecting to cable it is a coax cable or rca ect. ??
Posted on May 28, 2011
The picture is visible but there is a black small screen just covering the picture
Hello; If there is a black box covering part of the picture, it is likely a " TEXT " box that is used with " closed captioning " Read your owner's manual to see how to TURN OFF all closed captioning functions. Download the manual if you don't have one. John
Sep 18, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Under captions setting what cc1 and tx1etc. mean?
the tx is a box with writing in it, whereas cc is closed captioning, which is just writing on the screen. if the tx is unavailable, you will get a black screen. try the cc if you want closed captioning. good luck!
Apr 01, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
I have a blank, black screen, irrespective of the input (cable, dvd, wii). The menus, however, come up fine and the audio is working fine.
Your screen is showing a black picture because the closed caption function has been activated. When the closed caption mode is on the screen will display an 80% black picture.
To turn off the closed caption and regain a full screen please follow these steps;
1) Press the Menu button
2) Use the up and down arrows to navigate to Closed Caption
3) Use the right or left arrows to select it.
4) Use the right or left arrows to select OFF
5) Use the up or down arrows to select Finish
6) Use the right or left arrows to save the settings and exit.
You should have your full screen back now minus the annoying black box.
If this solution has helped please do take a moment to rate it.
Thanks for using FixYa
Dec 25, 2009 | JVC AV-32D305 32" TV
Issue with our Toshiba 50H82 - overnight it has stopped playing DVD's properly - a solid black rectangle obliterates 75% of the screen. Any idea?
Do you see same solid black box in all inputs or just in dvd picture?
If solid box appears only with dvd picture then its generated by dvd player, check dvd player Menu and turn off any subtitle settings.
And if solid black rectangular appears in all inputs of TV like cable etc then check Close Caption feature in TV and turn off CC function.
Hope this will solve your TV problem.
Thanks.
Nov 29, 2009 | Toshiba 50H82 50" Rear Projection...
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
The lower half of the screen is a black box on one channel
Check your closed-captioning settings. You probably have it set for "text". Make sure you turn captioning off and the problem should clear up.
Feb 12, 2009 | Recoton Advent Advent Q2035A 20" TV
Black screen
I work at at a school, and we had the same problem. Turns out, it a Closed Captioning problem.
We found the manual, and it states that "If a large black box covers 80% of your screen, the Text mode is probably set. Press 'Closed Caption' to turn it off." The "Closed Caption" button is on the remote. If you don't have the remote (as in our case), you can go to "Closed Caption" in the menu, and pick something like C4 and T4. That stopped the black box for us.
Jun 09, 2008 | Televison & Video
Tv PROBLEM
The black box your are seeing on the screen is the box to display text. It is listed under your "cc" closed captioning setting as T1, T2 etc. Go into your closed captioning and shut off the text. You can still leave closed captioning on or off. The text system was never really used but they put it on all of the TV's.
Feb 05, 2008 | JVC AV-27D303 27" TV
Black square in middle of screen about 25in X 25 in
If a black square appears on the screen and you can see the picture around the edges, it means that the closed captions are on and set to "TEXT". Go into the TV's menu, navigate to the closed captions page and set the captions to OFF.
Aug 10, 2007 | Mitsubishi CS-27407 27" TV
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Sharp 27N-S100 27" TV Logo
120 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
