Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I got a 2003. 52 in RCA D52W20 HDTV and I keep getting a code i cant get TV to turn it blinks 9 times then 5 times can anyone help me? ty
    Genius:
  • 1,030 Answers
This blinking is unfortantly not an error code. The one thing that you can determine from this blinking is that the main fuse. and the sub power supply is functioning. The blinking is also an indication that the cpu of the set is getting power.And its not simply a fuse.What is happing is some voltage or current is not right and the cpu is taking the set into shutdown for safety. In diagnoseing these sets first uplug the set and allow them to set for som time. not that long. Then plug them in and attempt to turn it on again. DID you hear a click? how about some high voltage static. The most common faliure of these sets that i have seen at the shop is the faluire of the high voltage transformer known as the flyback and when this fails it also takes what is known as the horizontal output transistor. The cpu will shut down the set for about 25 different reasons. Technicians have a computer interface that they ussally use to diagnose the problem.
Posted on May 29, 2011
RCA 52 in D52W20 that has no power, I have 1 blink followed by 9
Check these 3 capacitors on your Deflection board. its bottom board left hand side / cp150 2200uf16v and cp114 cp120 220uf 35v if any of them are swollen,vented or puffed up on top replace all 3 capacitors.
Mar 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w25 52 inch blinks 3 times off...turns on...off
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at www.tvrepairworld.com under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Sep 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on blinks 9 times then 1 time
I was inform that it could be a sensor (bad diode), you have to get a multimeter tester and test the diodes and if current flows from both sides then replace that diode.
Nov 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on blinks 9 times then 5 times
heat the deflection board with a hair dryer 1-2 min before turning on tv
May 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca tv wont turn on the light turns on and off three times
Rca d52w20 is a ict222 chasis i see this set all the time at the shop. The first thing to try on these set is to unplug them for 30 mins ( i dont think i ever have seen this work) What you need to know about these set is that the processor shuts this set down for any safety issues. it can be for many as 20 different issues. the processor stores this in a log which a technician with special computer interface can read. It will not be a main fuse because you can get the flashing light witch means the processor is getting power. So this is where the troubleshooting begins... these set are about 800 new. on average about 300 to 400 to repair. Notice any sounds or smells. What was it doing when the set died. did it ever run these will help whoever you get to work on it.
Feb 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
