Question about Garden
The pull cord is all the way out and won't retract. How do I get into the case to retract the cord or replace a broken starter spring.
  • Brian Stanfield May 30, 2011
    Never mind. I opened the case and found the problem. It took me a while to fix because the recoil spring unwound and it took me a while to rewind it. It had gotten rusty and stuck together. A little WD-40 fixed it and now it works great.
steve_lima
  • 181 Answers
SOURCE: THE STARTER REWIND SPRING IS BROKEN
you can not fix recoil spring all you can do is replace it.never said what the recoil is on so cann't help till you tell what it is on........
Posted on Jan 07, 2009
steve_lima
  • 181 Answers
SOURCE: Pull cord on chain saw will not retract.
make sure the spring is going the right direction when pulld,put spring back in recoil housing carefully if you do it to quick it could spring back on you..... yes it hurts. after you have the spring back in the recoil housing take the rope off rope rotor.that's the piece that holds the rope.always replace to rope even if it looks good...feed new rope on rope rotor, first heat he ends of the rope so it will go in the holes easier.tie a hove hand knot in on end of rope.....put rope in rotor and pull knot thight,feed rope onto rotor until you have no more room for rope.... there should be a notch in rotor for rope to lay in....install rotor and screw tha hold rotor in place....have recoil handle handy....holding on to the rope spin the rotor two rotations....install handle......please be careful
Posted on Jan 09, 2009
SOURCE: Spare parts for a Spear & Jackson chainsaw
I had the same problem
contact www.einhell-uk.co.uk
with ref: SPJCS3740
thanks
Posted on May 05, 2009
bobbyburns
SOURCE: Reattaching the recoil spring to the rope pulley
i have the same probelm
Posted on Jul 08, 2009
dontbother10
  • 2220 Answers
SOURCE: Starter recoil spring reload, How?
If the spring is unwound.
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If the starter cord needs a pretension, this works quite well.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 27, 2010
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
Pull cord won't retract
Hi Susan. It sounds like the spring has either snapped or become un attached. It's going to be a two person job to re do it. It may be worth while going to a scrap metal merchant and getting the recoil starter of an old mower.
Jul 26, 2013 | Poulan Garden
Starting cord won't retract
if its brand new take it back tell them the retraction spring is broken and fix it
Jul 25, 2013 | Garden
Poulan lawn mower cord won't retract
New or used unit? If new can you return it ? If not you will need to take the recoil assembly off the engine and rewind the spring. Check inside the recoil assembly to see if the spring is broken or just popped out of place on either end. If it is broken your done. You will need to find a Poulan dealer to get a new spring. If new take it to a Poulan dealer for warrenty replacement. If you want to try to rewind the spring look to see where one end of the spring fits into the housing and the other into the spool. On the edge of the puley should be a notch. Place the rope in the notch and turn the pulley it in the direction needed to wind the spring about 4 or 5 turns. If it now pulls all the rope in you are done.If not put the rope back in the notch and wind the spring tighter till the rope is all pulled in.
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Husky power cord reel won't retract
spring in cordreel is sprung. cord is probably on last leg. Go to vac replacement parts online store and order a new one.
Feb 04, 2013 | Vacuums
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
MANTIS 7225-00-02 cord won't retract
sounds like the spring broke or got stuck
Aug 16, 2012 | Garden
I have a Briggs & Stratton Sprint 3.75 hp lawnmower and it seems the cord is pulled almost all the way out and won't retract. How will i know if it is broken? or should I be able to wind it back up...
You should be able to Fix this yourself if your a fair garage tinkering mechanic. However...I need the engine and type number off of the engine to get you parts information. The spring is broken in your recoil. It is a matter of removing the air shroud, taking off the pulley / spool and changing the spring.
http://www.ehow.com/video_2328977_how-install-lawn-mower-starter.html
and how to tension the spring:
http://www.ehow.com/video_2328961_how-tension-lawn-mower-starter.html
There are 2 different types of springs used so having your engine model / type number is important so that you can get the right spring. One of the 2 part numbers is: 390066
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Briggs & Stratton Briggs Stratton...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
