My toshiba satellite A505 won't start with the power button after I powered it down. Any suggestions???
    Sergeant:
    Champion:
  • 218 Answers
Try removing the battery and power lead to kill power completely, it sounds like the hibernate mode has hung.
Posted on May 28, 2011
Wrt54gx2 won't stay powered up
Has the AC jack been damaged in the Linksys, due to pulling of the cord? Try wiggling the plug at the rear of the linksys to verify the connection. Check, reseat ALL cables. If it's connected to the ISP modem, can you use a Ethernet cable on the Linksys to the computer to verify signal? It may be bad, hard to say for sure.
Feb 14, 2013 | Linksys Wireless-G WRT54GX Router...
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
Toshiba a505-s6960 won't turn on
You should better go to the service center of Toshiba for the best solutions. The incident may have caused major issues to your laptop.
Regards, Mrityunjay.
Jun 19, 2012 | Toshiba Satellite A505-S6960 Core 2 Duo...
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
USB ports not working
jst see control panel usb setting or ur power scheme setings
Mar 23, 2012 | Toshiba Satellite A505 Notebook
Toshiba Satellite a135-s2386 won't bootup and CD/DVD drive won't open. The power button, plug button and battery button all come on. I tried taking out the RAM and switching the 2 RAM sticks. I also took...
I assume there is a specific reason that you mentioned the DVD drive won't open. Is it because there is a disk in it that you are trying to remove, and you can't because the laptop won't boot? You can open the DVD drive with a pin or paperclip. There is a little hole in the drive near the eject or open button. Insert a small pin or paperclip straight into that hole and push. It should pop open.
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
Toshiba Satellite A505-S6970 PC Notebook shut down often. Does anyone know why ? and how can I fix it ?
Is this using battery power or the wall charger?
If on battery power could be battery not holding charge... replace it
Make sure the machine will run on the power adapter without the battery in or it could be the adapter.
If it runs with or without the adapter and the battery is good it could be overheating and going through "Thermal shutdown"
This will be noticable by excessive heat and once it cools down you will be able to restart it.
Thermal shutdown can be cause by a bad fan or dust blocking the vents.
A can of "canned air" can be purchased for less then $10 and you can try blowing out all the vents.
However if the fan is bad it will need to be replaced
Dec 14, 2010 | Toshiba Satellite A505-S6970 Notebook
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
