Question about Garden
What is the spark plug gap setting for weed eater model XT 200
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
  • 57 Answers
SOURCE: Spark plug gap?
.030
Posted on May 18, 2009
  • 89 Answers
SOURCE: String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Posted on Nov 05, 2009
Testimonial: "Thanks for the help. We did look at the coil. Got about 30 volts out of it when we pulled the starter. I hope that means it's OK."
MOTORWIZJ
  • 1383 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
  • 5 Answers
SOURCE: weed eater won't start. changed spark plug,
possibly on/off switch-has it gotten wet? Also check where wiring from on/off switch meets the wiring from the weedeater body.Check those connectors/crimps make sure theyre plugged in /right fit and not wet.Make sure youre ground wire is grounded/attatched/screwed to the machine.Ive had a weedeater get wet twice at the on/off switch and had to bring it in the A.C. overnight to really dry out.It worked.Hope this helps.If none of this does then its maybe the coil(semi-internal-no fun) or the fat wire carrying the spark from the plug to the body(semi-internal-no fun).Good luck!
Posted on Jun 29, 2010
The gap on a Bosch R 10 spark plug for my stihl weed eater
Stihl Plug Gap 0.020" for all spark plug brands including Bosch R10. (Twenty thousandths of an inch)
Apr 24, 2017 | Bosch Garden
What is the gap setting for weed eater brand trimmer
Set the spark plug gap at 0.025 inch (0.6 mm).
Jan 24, 2016 | Champion Spark Plug RCJ6Y
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
What should the spark plug gap be on a 20cc weed eater fl 20
Small two-stroke engines typically have a spark plug gap of between .020 and .025. Either gap distance should work fine.
Mar 24, 2015 | Garden
SPARK PLUG GAP
0.02 in (or)
0.5 mm
Here is a link to the full manual. Spark plug info is on page 50.
HOPE THIS HELPS!
David http://www.stihlusa.com/admin/webcontent/cmsfilelibrary/instructionmanuals/fs120_200_250_manual.pdf
Apr 09, 2014 | Wolfgang Schmuck Total Scooter
What is the spark plug gap for weedeater bv 1850
You shouldn't need to set the gap on plugs when you buy them for handheld equipment. It should be close enough straight from the factory. You can find replacement spark plugs at PartsBuggy.com.
Oct 12, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Can't find owners manual for the following weed eater model numbers xt-200, xt-260 and poulan model # p35oo
XT200: http://www.weedeater.com/ddoc/WEEO/WEEO2004_USen/WEEO2004_USen__530163333.pdf
XT260: http://www.weedeater.com/ddoc/WEEO/WEEO2010_USen/WEEO2010_USen__545186831.pdf
P3500: http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2007/NOUS2007_545154718.pdf
Sep 06, 2011 | Garden
Nov 05, 2009 | Garden
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
