Question about Cycling
I need a manul for a Bon Aire WH-120 air compressor, I need to know which attackment I need to use to air up a wadeing pool, the hole is about 1".
SOURCE: Installation of down-draft exhaust duct for Jenn-Aire cook top
Minimal 6" duct no more than 20 feet long and 90's count as 5 feet. 90's must not be closer than 18" this will meet local codes regarding the venting also an approved exhaust hood. (not a dryer vent)
Posted on May 22, 2008
SOURCE: RADIO INSTALLING
with the bose sound system you have to bypass the audio system through the factory amp. the factory is located behind the right side of the glove box.
Posted on Sep 29, 2008
  • 89 Answers
SOURCE: kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Posted on Apr 20, 2009
  • 98 Answers
SOURCE: I have a Broom and Wade B.E.N air compressor type
Send me a picture, my e-mail address is fredericksimpson@bellsouth.net
Posted on Jul 21, 2009
erpaalai
  • 999 Answers
SOURCE: i need to rewire a 239 volt motor to 120 volts.
There should be a wire diagram on the motor tag or under the coverplate. Eric
Posted on Aug 11, 2009
How big is the oil tank.
There is no oil tank. The oil is in the crankcase of the compressor
Apr 10, 2013 | Bel Aire Compressors Bel Aire 5 Hp Air...
Need instructions for cleaning Salter Aire Plus Compressor 8350
Click here for the instruction manual. The cleaning instructions are on pages six,seven, and eight. Hope this helps! :]
May 29, 2011 | Salter Aire Plus Compressor
B zone is only cooling to 49 degrees and leds at L3 and L4 are blinking at 1 second intervals at circuit card on outdoor condensing unit. Is there a service manual available for download?
Hi
The L3 and L4 lights are blinking means that the filter is dirty and obstructed. You’ll need to clean the filter. Also Inspect whether the evaporator air is blocked, remove the blockage. Check the air intake and outlet ducts of the condenser side are obstructed. Check both of the ducts. Check whether the unit is set on dehumidifying mode. Set at cooling mode, Set at low fan speed Re-set the fan speed at high speed and check.
However, if this doesn't help then it might have happened that the compressor is not runing and the connection to the compressor is cut. Please check the wiring diagram on Pg 22 in this manual---
Comfort-Aire Air Conditioner Manual & wiring diagram
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Aug 02, 2010 | Comfort-Aire HMC18AD-1 Air Conditioner
Need diaphram for regulator for central pneumatic 42321
I used a FORD master cylinder gasket number 42098. It is the right overall diameter and I used a hole punch, slightly oiled, in my drill press to put in the four screw holes. The hardest thing is getting the nuts back on the screws to hold the switch together. But it works for $5.
May 26, 2010 | Bel Aire Compressors Bel Aire 5 Hp Air...
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Cycling Logo
55 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
