Question about Palm Z22 Handheld
After charging, the palm does not turn on - Palm Z22 Handheld
  • 3,083 Answers
Page 20 on the following Palm Manual explains performing a soft and hard reset, to try to get it working:
http://www.palm.com/us/support/handbooks/z22/en/z22_ug.pdf
I'm not familiar with the contacts on this device, but if there are any inside the device, and the battery isn't hard-wired, clean the battery contacts on the battery and inside the camera with a qtip and alcohol, or a pencil eraser.
Make sure the charger voltage is good (measure it with a voltmeter), and measure the battery to make sure it's holding a good charge). If it isn't, get a replacement.
Good luck, and hope this helps.
Posted on May 28, 2011
How would i know if my palm m500 is charging? while charging, do i need to turn on my computer???
Yes, you will need to turn on your computer for it to charge. You will see a charging indicator on the screen.
Thanks
Mar 08, 2010 | Palm m500, m505 & m515 Install CD (pa1456)
Power button unresponsive, always charging
Normal 0 Hi,
The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Normal 0 http://kb.palm.com/wps/portal/kb/na/tungsten/t5/unlocked/supportservices/page_en.html
Nov 26, 2009 | Palm Tungsten T5 - Multilingual Handheld
I stopped using my m505 for several months. How long until it will be charged enough to turn on? Its been charging now for at least 2 hours and nothing.
I would charge it over night. If the batteries went completely dead sometimes it takes an extended period of time to charge them. If that doesn't work try using the free palm chat. I have enclosed that link. Scroll to the bottom of the page and you will see Palm chat. From there click on the link that says chat now.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/m-series/m500/unlocked/supportservices/page_en.html
Nov 18, 2009 | Palm m505 Handheld
My palm Tungsten E won't turn on or won't turn off. Power Key may be broken... any suggestions?
Press one of the 5 buttons at the bottom, if they work, then the power key is broken. There is a freeware prc (off-it) that will turn the Palm off.
My experience with off-it, if you use it, and you want to charge your PDA, you need to turn it on and let it turn itself off via the time-out or leave it on and charge with the screen on.
Nov 03, 2009 | Palm Tungsten E Handheld
My Palm TX Handheld will not turn on, I have
It sounds like the battery might be dead. If I were you I would take advantage of the free chat that palm provides to their customers. I have used it in the past always with good results. I am including a link to that page. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
Scroll down until you see this.....
Other support options from Palm Palm Forums - free, always available - go there now
Learn from fellow Palm customers, or answer others' questions
Palm Chat - free, quick and simple - chat now
Communicate easily, securely, and instantly with a Palm agent.
Repair Services Open Check your warranty and learn about your repair options.
--> --> Warranty This product is covered under a limited warranty for 1 year. Eligible in-warranty repairs are offered at no charge for one year from the date of original purchase. You may be responsible for shipping charges. The warranty does not cover damage resulting from certain events or conditions. Please review your warranty for more information.
--> 2. Troubleshoot Review our solutions to determine if you can fix your issue on your own.
Try Troubleshooter --> Repair --> In warranty repair: --> To arrange for in-warranty service on your device, please contact Palm:
--> --> Out of warranty repair: -->
If the damage to your device falls outside warranty coverage, or if your device is no longer covered under the limited warranty period, you can arrange for an out-of-warranty repair from Palm. --> Cost: $199 US ($249 CAN)
--> --> Check repair status: If you have already started a repair with Palm, use our online repair status check:
Oct 27, 2009 | Palm TX Handheld
M515 Palm Pilot
here is your manual in PDF form
www.palm.com/us/support/handbooks/m500series_ug.pdf
if the unit was new then you would charge it for about 10 hours .. but since its not likely new then it doesnt hurt anything to just leave it on charge ... you can even operate the palm while its charging .. over night charge should be enough to get pretty close to full ... the palm internally automatically turns off the charge when the battery is full .. so you dont have to worry about over charging .. if the unit wont come on then you can do a "reset" (back at top)
Apr 01, 2009 | Palm m515 Handheld
Palm m130
If it needs to be charged, it can take up to 3 hours to do.  While it is charging you won't see any lights on the Palm.  Only the screen being turned on will indicate the charging level with the icon.
Sep 09, 2008 | Palm m130 Handheld
Palm treo 650 wont power up
It may be past the point of turning on.
If this is the case, if you connect it through the USB cable to your computer for a little while, it can get a small charge.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
If you can then power it on afterwards, connect it to the regular power charger.
Jan 06, 2008 | Palm Treo 650 Handheld
Won't shut down
There are a couple of things you can try.
1- Poke the hole in the back where it says reset.
This will in essence reboot your Palm.
2- Make sure the Auto-Off after: is set to 2 minutes by going into the Preferences, Power section.
3- If your Palm is not holding charge, connect the Palm to charge it. Turn the Palm on and make sure the battery at the top has a lightning bolt going through it. This will let you know it is charging. Then, push the reset hole in the back to reset the Palm. This should reset the charging mechanism in the Palm and allow your battery to hold power.
If the Palm does not hold power after step 3, you may need to see about getting it serviced.
Jan 04, 2008 | Palm Tungsten E2 Handheld
My palm Z22 froze
I have the same problem. I fixed it the first time by rebooting from the back of the palm and plugging it in to charge. Not sure if it needed charged or not but it worked. I am having the same problem today though and know it doesn't need charged so not sure if this is a true fix but got me back up and running the first time.
Sep 14, 2007 | Palm Z22 Handheld
Palm Z22 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
