Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Machine stopped functioning while plugged in.
We have had the combi pump espresso machine for about a year now. This morning we used the machine to make a double shot of espresso. By the afternoon we noticed that the display was no longer on and there was no response when pressing the on/off button - we tested the outlet with another appliance to be sure that wasn't the problem. Please help - we love this machine and hope it is still functional!
    New Friend:
  • 39 Answers
It appears to be the power module at the bottom of the unit. Service centers sell a replacement unit that includes the control/display module. I don't know how much they charge to replace it. Replacing the power module requires comple disassembly of the unit to make the new connections to the thermal block, solenoid, pump, coffee heaters and control module. You have to take good notes on the connections and it could be a safety risk.
Posted on Dec 31, 2009
My espresso maker wont drip out any espresso, Ive tried cleaning it with water and vinegar but that didnt help. What can I do
remove any filters and try again use small niddle to open any blocked nossles . does the water pump works try to run some water free first
Dec 16, 2015 | Krups XP604050 Coffee Maker and Espresso...
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
My keurig stopped pumping water.
Now the debris is loose and clooged the system. Your toast now.
Nov 10, 2012 | Keurig Elite B40 Coffee Maker
When I press the button to select a large cup of coffee the water will run for about two seconds then stop but the pump is still running and the third light stays on. Even when I pull the plug and reset it...
I read a couple reviews on this machine, and it could be that your water pump is bad and need to be replaced.
Another problem could be that the bay beneath the coffee cup is full with water and needs to be drained. I have an nespresso brand espresso machine, and when this bay becomes to full with water, the machine stops brewing espresso/coffee. This function is there to prevent water messes.
These are the only possibilities I can think of. Good luck.
Nov 27, 2010 | Keurig B60 Coffee Maker
Everything works on my Briel Sintra, but the espresso part!
Adjust the grind on the coffee or the tamping / packing pressure on the grounds.
Jun 22, 2009 | Briel Sintra ED-132 Espresso & Coffee...
Can't program my machine....its a model no.sup02148dr
Hi
You may be in the descale mode. Try removing the water tank when the pump is running and see if the pump stops.
Apr 25, 2009 | Saeco Incanto Classic Espresso Machine
How to Prime Spidem Trevi Combi Plus Espresso Machine
Open the steam knob on the side and make a cup of water (Tea).
Best regards
/Mirran
Oct 23, 2008 | Spidem Trevi Automatic Espresso Machine
Not building pressue
Water damage to the flow meter can cause the machine to not function at all. We have seen water leaking from the water tank leaks right on the flow meter and stops the machine from heating and contining its start up proceedure.
Espresso machine Sales and Service.
www.CeriniCoffee.com
johnny@cerinicoffee.com
Sep 04, 2008 | Pasquini Livia 90 Espresso Machine
Spidem Trevi-the water is not traveling through the machine to allow the machine to make the espresso.
hi, i have a trevi i bought used with no manual and had problems starting with it, i found an airlock stopping water flowing, i held the water bin over the sink and pressed the valve on the bottom until water flowed out, i do this now when filling the bin and have not had any problems so far. i am still trying to find a copy of manual. i hope this may be your problem as it is easy to remedy. col.
Jan 01, 2008 | Spidem Trevi Combi Plus S2231 Espresso...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
849 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
