Need drivers for router BR-6204WG for vista - Computers & Internet
    Sergeant:
  • 221 Answers
You do not need drivers for your router. Routers have their own operating system installed, called the IOS, it is a stand alone device. You simply log into the router via web utility and adjust the settings as desired.
Posted on Aug 16, 2008
Edimax br 6204wg
IT NEED SOME SERVICE
Nov 02, 2013 | Computers & Internet
How to set up edimax BR-6240WLG
Here is a quick install guide:
http://www.edimax.co.uk/images/Image/QIG/Wireless/BR-6204Wg/BR-6204Wg_QIG_English.pdf
Hope this helps you.
Jul 16, 2011 | Computers & Internet
Hello I've installed windows7 on my pc, now i'v...
This message has nothing to do with your router. Windows 7 is not recognizing your network adapter card possibly due to an incompatible driver.
You need to ensure that your network card has a driver that is compatible with Windows 7 and is installed and working properly.
If you right click on My Computer on the desktop and choose Manage look for Device Manager in the left pane and click on it. Now in the right pane you should see a listing for Network Adapters. First of all if it is yellow with an question mark it means that the driver either is not installed or is not functioning. you will need to find the driver for that network card and install it.
If it looks ok check the version by right clicking on it and selecting properties. Confirm with the vendor that this driver is Windows 7 compatible. If not you may be able to find a generic Microsoft driver that will work.
If that all fails you will need to get and install another network card that is compatible with this operating system.
May 20, 2010 | Computers & Internet
My laptop can't connect with my wlan edimax router BR-6204Wg,,,, wlan light indicator flinks orange,,,
Reset everything including the Hard reset (a small probably hidden button you must press for 15 seconds) you will find somewhere on the wireless router. I trust your laptop is capable of connecting wirelessly???and you have done this before???
Sep 21, 2009 | Edimax BR-6114Wg Router (BR6114WG)
I am using Edimax Br-6204Wg. How can I reset wireless password?
Try this link its your router's manual from its manufacturer's site. Drop down page then click manual it will download your manual. Then read from resetting the router and default user and password.
http://www.edimax.com/en/produce_detail.php?pd_id=11&pl1_id=1&pl2_id=2#03
Be aware that by doing the reset the router will be back from default settings.
Goodluck.
Jul 10, 2009 | Computers & Internet
Defalt code and password for a edimax br-6204wg
The default settings for your router are : 192.168.2.1 User name :admin and the Password is : 1234
Jun 18, 2009 | Edimax Computers & Internet
Edimax BR-6204WG: canNOT login to router website
The deal is that you can access that site only with the router identified by your connect. If you're trying to login from a different connection, it doesn't match the IP address. And it automatically locks it.
When the connection problem was resolved, the password and username worked.
Feb 08, 2009 | Edimax BR-6104 Broadband Router. One...
Asks for IP address and password
Try reading the Quick Installationguide and see of that helps.
http://www.edimax.com/images/Image/QIG/Wireless/BR-6204Wg/BR-XXXX_QIG.zip
Nov 03, 2008 | Edimax BR-6104K Router (br6104k)
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
