Question about Keurig B60 Coffee Maker
My keurig coffee maker dose not fill cup..ex..small..med..lg..very little water comes out..makes coffe super strong
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 05, 2011
My keurig coffee maker shuts off after making a small amount of coffee
You should put it through a cleaning cycle of vigner and let it stand for about 4 hour in this state. After rinse through with clean water about 3 times. The pump may need a good cleaning. I do this about once every 2 months.
Sep 30, 2014 | Keurig Starbucks Single Serving K-Cup...
De scale kruig coffe maker
Empty the reservoir of water and fill it with four (4) cups of white vinegar. Run the Keurig WITHOUT a K-Cup until the vinegar has been run through. Rinse out the reservoir with hot water, dry it, then fill with cold water normally used to make coffee. Run the maker 3 times, or until vinegar taste disappears.
Dec 25, 2011 | Keurig B60 Coffee Maker
Weak coffee, using purified water...my husband, who doesn't really like strong coffe (neither do I) is complaining it's too weak. I have to admit, it is. I opened the foil on the kcup and half...
Hi, Check the bottom needle....it is plugged
heatman101
Aug 14, 2011 | Keurig Platinum B70 Coffee Maker
My keurig coffe maker says it id "brewing" but
heatman101
Aug 09, 2011 | Keurig B100 Coffee Maker
Won"t brew the coffe right and hot water coming
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
Brewer not filling complete cup, then fill water and small cup lights blinking at same time continuously
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
May 14, 2011 | Keurig Elite B40 Coffee Maker
My keurig B40 coffee maker just pure out water hardly any coffee. It makes it taste like a weak coffee even when it's should be strong. It was blocked and we try vinegar but that wasn't the problem. We...
Look at the top needle, there should be a rubber like seal that sits around its base. This seals the needle so all the water with pressure goes the the cup. If the seals not there, it can't build the water pressure necessary to go through the coffee inside the cup, thus coming out around needle and out around cup, making it mostly water in your coffe cup.
Mar 03, 2011 | Keurig Elite B40 Coffee Maker
THE 1 CUP KEURIG DOESN'T BREW COFFE. THE WATER GETS HOT BUT NEVER GOES THROUGH THE MACHINE TO MAKE THE COFFE
heatman101
Mar 01, 2011 | Keurig B60 Coffee Maker
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Keurig B60 Coffee Maker Logo
127 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
