Question about Pentair PUREX MINIMAX HEATER; THERMOSTAT, 60 CAPILLARY - 072022
I have the Triton Purex 500M pool/spa Gas Heater(Natural gas) and the valve was replaced last year, I opened my pool three weeks ago and the heater was working but turing its self on and off then the wind blew the pilot out so it took me several attempts to get the ignitor to spark and relight the pilot and now the pilot is lit but the heater is not kicking on, the pool option on the switch is out so I have been using the spa option to heat my pool so I am thinking either the switch is out or water might not be flowing correctly. I just cleaned my filters out and the pressure on my pump is around 100 psi which is usually fine, I have a sand filter, and it is still not kicking on even with the pilot lit and ok, so I am wondering what is going on..... also we just had a bad wind and rain storm and I do have a hood stack so does water have anything to do with it, if so what can I do to in the future to prevent this, I live in Idaho where we can only use our pool five months out of the year and it is closed the rest of the year, thankyou so much for your time and help with this, Amanda Anaya
    Top Expert:
  • Pentair Master
  • 8,694 Answers
Check all wires make sure tight and pressure switch
Posted on Aug 30, 2017
4 Suggested Answers
  • 139 Answers
SOURCE: The pool and spa heater, purex triton, show a code
sounds like flame sensor is dirty,they rarely go bad.remove and clean with steel wool or fine emory cloth
Posted on Jun 21, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
SOURCE: purex triton powermax 400-
This is usually either the Thermal Overload Cutoff (an inline fuse to prevent overheating) which costs $13.50 through poolcenter.com, or it is that you are not getting enough water pressure through the heater. There are sensors that will shut down the heater if there is not enough water flow. Is your filter clean so enough pressure/flow is happening?
Posted on May 02, 2010
Error message Fault. High Limit , upon attempting to use the heater for the first time this season
either not enough water flowing through heater or low gas pressure to overheat unit replace high limit in stack if not one replace one on bottom white unit with 2 white wires
May 26, 2016 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
or...
In coming water to heater is over 104°
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
Purex triton powermax 400- gas ignites for a moment and then shuts off - basically cycles on and off for the spa. any idea to the problem?
Feb 15, 2010 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Flo 6 showing on display panel?
DO YOU HAVE ALL THE WIRES CONNECTED? IF YES POWER MODULE MUST BE REPLACE
Jun 28, 2009 | Jandy Lite2 Lj175n 175,000 Btu Natural...
Triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Jun 27, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Have a Triton Millivolt pool heater pilot is lit and nothing!!
Low out put voltage from the pilot generator and/or an open circuit in the control circuit...the most common is a bad pressure switch (dirty filters can hamper pressure switch operation).
Jun 08, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Pentair PUREX MINIMAX HEATER; THERMOSTAT, 60 CAPILLARY - 072022 Logo
125 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
