Question about Sony KDF-E50A12U 50" LCD HDTV
Kdf-e50a12u. just replaced bulb and tv was working for 5 mins then turned off and I have flashing red, green, red, each for 1 second then a 3 second green, then repeat.
  • 643 Answers
Your fan or balast is bad. Try replacing the fan first. Sounds like a thermal sensor is tripping. Hope this helps.
Posted on May 28, 2011
  • 1 more comment
  • ray7540 Jul 09, 2011
    Where can i find the thermal sensor ? I have the exact same problem, aslo after changing the lamp. the door mechanism works fine, but i get 2 red blinks when the tv goes off after 2 mins, now i can't even turn it on again at all.
  • Mando Mojica
    Mando Mojica Jul 12, 2011
    Try going to esupport.sony.com
  • Dave Bond May 20, 2012
    With the rear cover off the heat sensor is 1/2-3/3" in size in an oval case with 2 connections just to right of the fan unit, same as used on tumble driers, was a Year ago you left query so you may have got rid of it by now.
Sony 50" new bulb but powers off after 1 minute?
if you was sure about lamp defective the you replace the lamp if was giving the same problem before .if not check lamp switch in side close to connection.one of the swith may be not making contact
Mar 01, 2012 | Sony KDF-E50A12U 50" LCD HDTV
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
Mar 02, 2010 | Televison & Video
Sony kdf-e50a12u my tv flashes the green power light only
How may flashes the LED does? This error code will tell you what is the problem.
Aug 02, 2017 | Sony KDF-E50A12U 50" LCD HDTV
The tv doesn't stay on. it turns on for 4 seconds and goes off... then comes back on and goes off.
If its Sony KDF-E50A12U TV then its problem of weak lamp in TV that will be replaced and problem will be fixed. Lamp light on TV front will lit in case lamp is dead or broken but current symptom shows Lamp is not either dead or broken yet it got weak in result and causing problem.
Lamp replacement is easy and would be written in user manual.
Please but Sony original lamp for TV safety.
Let me know if you have additional question.
Thanks.
Jan 13, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Sony KDF-E50A12U TV Swith on ok, after about 30 seconds the tv goes into standby mode, green power light on with 3 rapid red flashing lights. Any assistance appreciated
red light flashing means it can't dectect lamp housing. you can try and take it out (door on side of TV to the right hand side) and reinsert. But it probably means your lamp has blown. Replacement xl-2400 lamp is east to replace. Search ebay to buy one (about £100) and youtube has a video showing how to do it.
Dec 22, 2008 | Televison & Video
SONY BRAVIA 50IN KDF E50A12U
i have the same problem on mine, my tv is only just 12 months old, in the last 4 weeks it had 2 new blocks put in as the tv was blue, it costing £700 each (under guarante for 3 years thank god) then lastnight the tv made a big bang then switched it self off and the sand by botton is now flashing red then green, i have to leave it 30 mins before i switch it on again then only last 10 mins before it does the same thing again, got sony coming out again to day to fix it, had it with this tv now hate it !!!!!
Sep 01, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony KDF-E50A12U 50" LCD HDTV Logo
674 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
