Question about SanDisk 4GB microSDHC Memory Card
I just bought the SanDisk 4GB Memory Card. Where can I go to get instructions on how to install and use it? Thanks, JG
5 Suggested Answers
  • 1082 Answers
SOURCE: Was using a 4GB SanDisk
The card appears to be defective. Replace the card.
There is a small chance if some crud on the contacts, but sounds like you have removed and inserted a few times.
Return it to where you bought it.. for exchange or refund.
You could try to format the card in a PC, but even that sounds unlikely by your description.
If you can see the card in the PC there is SoftWare that can try to recover defective pics from card.
But if you can not "see" the card in a PC, the SW is a waste of time.
link to google search for SW
http://www.google.com/#sclient=psy&hl=en&safe=off&q=recover+pictures+from+memory+card&aq=0&aqi=g4g-o1&aql=f&oq=recover+pic&gs_rfai=&pbx=1&fp=1d02e3dd4442100f
Posted on Nov 16, 2010
Geekman
  • 32281 Answers
SOURCE: My sandisk memory card of 4gb shows 0 bytes how do
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Posted on Apr 25, 2011
bronk50
  • 27725 Answers
SOURCE: Forgot my memory card password ( sandisk 4gb microsd hc ).it said the i need to enter my password ,is there any things that can help me to fix my problem??
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Posted on Aug 15, 2012
bronk50
  • 27725 Answers
SOURCE: when i put music into my sandisk 4gb memory card from pc after that from mobile it shows unsupported file please help
right click on the music file/s you can select which proram opens it
and you can select a default program
hope this helps
Posted on Oct 04, 2012
4gb sd card not format problam format uncomplet
I'm assuming you are having a problem formatting the memory card?
The soultion would be to connect it to a PC or laptop that has a card reader installed, then format the card via Windows.
If it is a micro SD card, you may need an adapter to convert it to a SD card.
Thanks,
Aug 11, 2010 | SanDisk 4GB microSD High Capacity Memory...
Hello. I have installed the sandisk sd 4Gb card into the slot in my lg pop but the phone does not see it. do I nee to do something? many thanks
You may need to format the memory card first before you can use it. Refer to the packaging and documentation of the memory card, or refer to your phone's manual regarding using SD cards. You may be able to format the card while it is in your phone, or you may have to insert it into the adapter and plug it into a computer to format it. The following link has walkthroughs of both methods of formatting an SD card:
http://www.ehow.com/how_4913062_format-sandisk-micro-sd-card.html
Jul 17, 2010 | SanDisk 4GB microSD High Capacity Memory...
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
SanDisk 4GB MicroSD HC Memory Card is not recognized by my Sansa
sd utility.exe u download from google it wil dolve u r problem.......
Sep 29, 2009 | SanDisk 4GB microSD High Capacity Memory...
I just bought a SanDisk 4GB microSDHC card at walmart and it shows up in my phone, but not my computer. How can I put music on it? Is this the right card I need?
What is your operating system? What is your card file system? If your operating system support FAT file system then check your memory card reader. If all is ok then try it with your data cable of your phone.
Jun 08, 2009 | SanDisk 4GB microSDHC Memory Card
SanDisk 4GB microSD corrupted
If the card is brand new, try to have the phone to format it, or use the PC to format it at FAT, not FAT32 or any other file system.
Mar 17, 2009 | SanDisk 4GB microSD High Capacity Memory...
Pentax K200D Digital SLR - Error Message "f - - "
This can also happen when the lens have an aperture adjustment ring, and it is not set to the "Auto" setting ("A", on my Sigma)/
Dec 25, 2008 | Pentax K200D Digital Camera with 18-55mm...
SanDisk 4GB microSDHC Memory Card Logo
201 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
