Question about Frigidaire Freezers
I have an older Frigidaire Upright Freezer Model FF160LWHWH & I need to either defrost it or turn it down. How do I do this, there isn't a temp control anywhere?
fridgetech
  • 473 Answers
SOURCE: older frigidaire upright freezer not working
Sounds like the relay on the compressor is bad and will need to be replaced.
Posted on Nov 16, 2007
SOURCE: my freezer temp.warning light has come on and wont cool anymore.
freezer temp light stays on
Posted on Jun 25, 2009
SOURCE: Freezer will not turn on
I have a whirlpool upright freezer model ev190nxsn01 it keeps popping the breaker. i disconnect the timmer the comp runs,ichanged the timmer,still pops breaker, i disconnected evap fan still pops breaber. please help if possible thanks for your help.
Posted on Aug 04, 2009
SOURCE: Where is the Adaptive Defrost Board on a Frigidaire GLHS36EEQ6?
The board is located under the freezer side of the unit. You can call Sears, as they carry your brand's parts and they will tell you exactly where it is. There are diagrams on the web too. Search for appliance parts. You'll need to enter model number here: www3.sears.com
Fridgidaire refrigerator repair in Orange County, CA
Posted on Feb 05, 2010
  • 4793 Answers
SOURCE: Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Posted on Feb 22, 2010
I have a frigidaire stand up freezer model #lffh21f7hw, and the door isn't vacumn sealing the door, why?
If you have too much weight in the door or someone pulled down in the door, it gets twisted. Try lifting up on the bottom outside corner of the door to straighten it up. You might have to loosen the top hinge to reseat it.
Jan 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How does the Frigidaire FFU1764 Upright Freezer defrost?
Download its manual here and then read through the defrost section. It should run every 12-24 hours.
Aug 23, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
Freezer cools some to a refirdgerator level, however will not freeze
A few suggestions are 1. Turn down the fridge portion a little and colder air should redirect into the freezer part 2. If it is an older unit sometimes defrost it , unplug it and turn it upside down for a day or so (this moves some of the corrosion inside the pipes). Turn it back up and plug it back in .
Aug 30, 2011 | Frigidaire 20.6 cu. ft. / 583 liter...
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I moved my upright freezer so I unplugged it , moved it and plugged it back in and it stopped working. I left it unplugged overnight, plugged it back in, same result. Any suggestions?
Maybe it is in the middle of a 21 minute defrost cycle? Is the fan running? Sometimes the defrost timer gets hung in defrost. If that is fine I would see if 120 volts is getting to the relay on the compressor. Sometimes an older temp control will die if fiddled with. Did you turn it before moving the freezer? Those are some things I would check. Sometimes wires get yanked out of place when you move an appliance so check that as well. Post your model number and I might have a service manual you can download OR just go to my website and find one HERE
Dec 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Upright freezer not cold enough
IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
Apr 02, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezers Logo
159 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
