Question about Vector VEC 024 400-Watt Power Inverter (VEC 024) 400-Watt Power Supply
Does item have a fuse? Burned out
I plugged a coffee percolater in this power inverter and it was too much power for it. It no longer turns on. Does it have a fuse or breaker or is it toast?
  • AAAADAD Mar 23, 2009
    VECTOR VEC 414
    CANT FGIND FUSE
Has 2 of the internally, Did you hook up a CFL or similar device to it, I did.... DUGH
Posted on Dec 04, 2011
    Sergeant:
    Champion:
  • 298 Answers
I have the same one ...and i'm not seeing a fuse, there may be one internally
does the inverter have strong "burnt wire" smell if so it is probably fried.
Posted on Aug 16, 2008
Power is on, but appliances connected to the inverter are not working.
power surge or not enough power to the inverter for the items you are running,remember,compressors and heating elements and motors use 3 times as much as ratings to use or start,if you have those hooked up,then the inverter is burned out
May 20, 2015 | Electronics - Others
How do you reset
When you say a power reset button, do you mean the power button you turn on to power it up or a fuse? I doubt any coffee maker has a fuse any longer. If it does have a fuse, it's internal and you'll have to dismantle the coffee maker and find a replacement. You can find some fuses real cheap at Walmart.
Jul 22, 2014 | Black & Decker Spacemaker 10-Cup Coffee...
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
Turn the computer the only thing that light up is the charging light batt..
Most cases there is no need to replace the motherboard. Try to find out what component has burned and replace it. If the main power supply to the inverter board had shorted, then, the supply giving FET may be burned. You may see as it burned. If the inverter activating device ( a small FET) had burned, you can also see it. In some systems there is a fuse for the inverter supply in inverter board as well as on the motherboard. You can also identify it.Make a reply if this is helpful.
Apr 19, 2010 | HP Pavilion dv1000 Notebook
Coffee is not hot
Either you have a corroded electrical connection (probably in the plug) or an element is bad. Try cleaning both ends of the removeable plug until they are shiny.
Jan 24, 2010 | Faberware FCP240 Coffee Maker
Can't get power to my RoadPro 1500 DC to AC Power Inverter
I have had this same problem with several power inverters over time. The problem is usually one of three things.
Those starting with the simplest.
1. Too much current being drawn on the inverter.
Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
Solution (Replace the fuses)
3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
Hope that helps.
Jan 20, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
7006 percolater
262-626-2121 OR WWW.REGALWARE,COM
Jan 16, 2009 | Regal Ware (RW58230R) 30-Cup Coffee Maker
Power problem
Hello Aleone
you will need to take your Tv to a repair shop and have them replace the power supply.
Aug 05, 2008 | Hitachi 55HDS69 55 in. Plasma Television
I live in asolar powered home and my westbend 3 in 1 coffee maker has quit after one use. Might the initial power surge from the inverter to run the machine burned it out?
more than likely, either the coffee maker has a fuse inside of it, or the inverters lack of a perfect sine wave a/c fried it.
Mar 05, 2008 | Washing Machines
Vector VEC 024 400-Watt Power Inverter (VEC 024) 400-Watt Power Supply Logo
222 people viewed this question
Top Vector Computers & Internet Experts
Jonathon summesfield
janman
Are you a Vector Computer and Internet Expert? Answer questions, earn points and help others
