Question about Siemens Freezer GS 28E420
My siemens frizer is not cooling but the frezer walls is cold the temperatura inside +7 c .
My frezer is getting hot on the sides-why?
Its normal. The manufacturers got smart and put the condenser in the outside freezer walls. A lot of home refrigerators also have the same hot walls. Hope this helps good luck.
Oct 06, 2014 | Kenmore Freezers
Why does it get hot on the front and the sides it never did that before
If the food is at normal temperature, then what you are describing is normal.
On a chest freezer the condenser coils are embedded in the outer walls, as the evaporator coils are embedded in the inner walls to provide cooling.
This is the very basic principle of refrigeration. One set of coils (the condenser) are allowed to get hot, so the other set of coils
(the evaporator) can get cold.
When the unit is not running, which is most of the time, the walls will cool to room temperature.
Nov 03, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Do i put frozen food in my freezer as soon as i get it, or do i have to wait a few hours?
The frozen food will actually help cool the compartment. Just be sure to watch the unit and feel the inside walls to be sure it's actually cooling down. I'm sure you realize that every so often one does NOT cool right from the factory.
If you haven't shopped for the food yet I would wait until you feel it's cold enough. Just in case.
Aug 23, 2009 | Danby Freezers
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
Fridge wont cool but frezer is fine
looks like you have a problem with the damper control. try to locate the sensor for the damper control and relocate it, if still not cold, replace it.
May 04, 2009 | Freezers
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Freezer not getting cold enough
I think your system has a leak and has lost the refrigerant charge.
The only way to check is by accessing the sealed system. Most systems are covered for five years on the compressor. Contact the place of purchase and give them your indications for your problem.
Jul 06, 2008 | Freezers
Akai frizer
on the top of the motor there is a plastic cover which contains a thermal button,try to hit it in this spot and if it works you might change it with another
Nov 18, 2007 | Freezers
Freezers Logo
Top Siemens Freezers Experts
Charles T Nevin
Charles T Nevin
Phillip Hicks
Phillip Hicks
John Tripp
John Tripp
Are you a Siemens Freezer Expert? Answer questions, earn points and help others
