SOURCE: sanyo vpc s1275 lens error 0x0311
Well lens errors are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism.
Check the below link to do a try to correct it -
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor. This part is replaceable at an authorized Sanyo Service Center. Aprox repair cost is $120.
Good Luck!!
SOURCE: sanyo camera vpc-s1275 lens error 0x0211
i there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
SOURCE: I have a sanyo vpc-e760
This
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Sanyo service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
Good
luck, I hope you manage to use this information to fix your camera.
Please take a moment to rate the free answer I have provided for you.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
SOURCE: sanyo vpc-s1275 saying lens error 0x0311
Apologies for
the extreme delay in answering, I've just been specifically searching
for old unanswered questions. I realise that the information is probably
far too late for you, but it may help others searching the site for
answers to the same problem.
Your camera has a lens error,
this
The fault is
become
If your camera
the
by
Please click here
manipulate your camera to try and clear the fault. Although the article
mentions Canon a few times, the advice applies equally to all cameras
with lens errors and is not model-specific.
Please take a moment to rate the free answer I have provided.
