Question about HEWLETT-PACKARD ProBook 4520s
Unable to get microsoft mouse to point as touchpad less than user friendly
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
Unable to double click on laptop touchpad but able to move mouse
Hello Friend,
Try this
  • Go to Control Panel
  • Open Mouse
  • In Button Tab
  • Adjust 'Double Click Speed' to Middle Point
  • Click Apply and OK
  • You are Done
Just Restart PC...Hope This HELPED you...Thanks for Contacting FixYa....
May 29, 2010 | Dell U0636 Mouse
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Unable to connect to the synaptics pointing device driver
Go to Start -> Control Panel -> System -> Hardware tab -> Click "Device Manager" -> Find the item called Mice and pointing devices and click the + sign.
If synaptics is listed right click and select Uninstall.
After that completes go to the top of the Device Manager and select Action -> Scan for hardware changes...it should find the device and attempt to reinstall it and the driver.
Thanks for using FixYa - If you
Apr 29, 2009 | Logitech Marble Mouse Trackball
How do i operate the mouse on a toshiba 8200
hi, you probably have to disable the touchpad, for the microsoft mouse to work properly, i had same problem on my notebook. i conflict of software for touchpad made my microsoft cordless mouse not work, until i removed the touchpad software. i hope this is helpful,good luck!
Feb 13, 2009 | Microsoft Wireless Optical Mouse
Touch pad possessed.
For extra USB ports, purchase a USB hub($15 -$20). That way you can add at least 4 USB ports to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Acer aspire 3692WLMI - problem with arrow
Go to acer website and download that model manual, make sure you have ADOBE READER on this machine..If your pointer is not working then you need to download the touchpad driver or if you are using a mouse then it may be a bad one.
Aug 24, 2008 | Acer Aspire 3690-2196 Notebook
Synaptics touchpad totally dead no response!
Right click the Synaptics Pointing Device and select Pointing device properties OR double click the Synaptics Pointing Device. A Mouse Properties Dialogue is displayed, then select the Device Setting Tab and then select the synaptics device under device section then select the enable button and lasting select the the Apply button.
Jul 08, 2008 | Computers & Internet
Wireless mouse batteries
refer this link please http://techgage.com/article/microsoft_wireless_notebook_optical_mouse_3000/2
Feb 28, 2007 | Microsoft Notebook Optical Mouse 3000 1.0...
HEWLETT-PACKARD ProBook 4520s Logo
66 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
