Question about HP Deskjet D1455 InkJet Printer
Printer jam error 8 jobs waiting. paper is feeding thru printer fine. how do i clear
  • 543 Answers
You can clear it, but it can not work correctly, or.... Will be well if you change your printer to laserjet
Posted on May 28, 2011
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Error paper jam
Hello Cassandra,
It sounds like you are having phantom paper jams. When the printer starts a print job and tries to pull a piece of paper but can't grab it the printer thinks there is a jam but there really is not. If the paper pickup rollers are worn down they are not able to grab the paper correctly to feed it into the printer which causes this type of error. The rollers are considered user installable and come in a kit with the rollers and the paper separation pad which keeps more than one paper from being pickup up at the same time. Installing the paper feed kit should clear up your paper feed problems. The paper feed kit is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=342
I hope this helps.
BuddyMc
Aug 06, 2013 | HP CP3525N Color LaserJet Printer
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
I have a HP Office Jet Pro 8500 A909a My wife sent
1) Turn the printer OFF.
2) Unplug the printer's AC adapter fro the rear of the printer.
3) Unplug the AC adapter cord from the wall outlet.
4) Wait a FULL 10 minutes minimum...While waiting, go to step 5.
5) Remove the rear access door. Reach inside and rotate the rubber feed rollers on the shaft with your thumbs until they stop/click.
6) Use a can of compressed air and blow out the entire access interior.
7) Use a magnifying glass and a flashlight to to inspect for bits of torn paper or other foreign object that may still be locking the feed sensor in the feed position.
8) Try to locate the sensor and see if it is stuck. It should be spring-loaded and easy to move with a narrow screwdriver or pick.
9) Put the access door back into place (make sure it is completely closed/seated)
10) Plug the AC/power cables back in, turn the power button ON and test for a normal print process.
Dec 03, 2011 | Computers & Internet
Canon MP198 error E3
Issue: ERROR LED: E, 3 Solution: Remove paper jam then press Black or Color button (MP150) If paper is jammed, remove the paper jam then press <Black> or <Color> to clear the error.If paper is jammed in the auto sheet feeder or paper output slot, paper will not feed through the printer. Please follow the instructions for Clearing paper jams from the auto sheet feeder (ASF) or paper output slot.If Credit Card sized or 4" x 6" paper is set in landscape orientation, it will jam. Please follow the instructions below for Clearing credit card-sized or 4" x 6" paper jammed inside the printer.Clearing credit card-sized or 4" x 6" paper jammed inside the printer:Power the printer off.Load the same paper type as the jammed paper in the portrait orientation. Power the printer on. (The printer feeds the paper, resulting in ejecting the jammed paper.) Load paper properly in the portrait orientation to resume printing.TOP Clearing paper jams from the auto sheet feeder (ASF) or paper output slot:Power the printer off.Pull out the paper gently.If torn paper remains within the printer, open the scanning unit (printer cover) to remove it.Caution: To prevent injury or damage to the unit avoid touching inner parts.Power the printer on and confirm that the Alarm lamp is off.Note: Any jammed paper that remains within the printer may be ejected automatically.Load paper properly to resume printing. Issue: ERROR LED: E, 3 Solution: 2 Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times.Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue.For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing. This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
E3 on LED paperwill not feed
What you want to do is remove all paper, the prepare to run a print test page or print a blank sheet from some program, any program. Just be ready to do this.
Now, find a magazine cover or index card stock, something firm. Cut this magazine cover to the same width as regular paper 8 1/2 in the US or A4 in Eurpoe.
Now, when you start the print job, push the magazine cover or index stock through while its printing. Apply pressure it the key, to getting the thicker paper through.
This will clear the sensors in the printer and remove the error message.
Why did this happen? In the printer, there are numerous sensors to identify jammed paper. This can happen for the strangest reasons. By pushing thicker paper through while feeding paper by running a print job, the thicker paper forces the sensors back to their original position.
Regards,
Worldvet
Nov 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jam
hi y'all -
you share a frustrating problem... error message but no apparent error (jam)! it's one that's common to many models of printers and the result of many different causes.
I've seen it when I've printed on cheaper paper, or different (lower) grades with odd surface finishes. the sensors get dirty, or the printer/computer 'thinks' there's paper stuck where none exists. I've opened/closed paper trays 2-3 times and rolled feed rollers around multiple times, then closed printer paper drawers only to have the 3rd time of doing the exact same steps be the time it cleared the error message.
there are often very tiny pieces of paper stuck in weird places in the paper path in printers, too. if you did have a jam before the message started, is every little scrap of the page accounted for? there are also hard to get to places to find paper scraps in larger printers, but I'm going to assume you're all talking about home printers.
here are a few general HP support links you may find helpful for future paper jam messages for this model of printer.
this link is for general info for this model:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=304535&lc=en&jumpid=reg_R1002_USEN
this link is for general support for this model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535
here's a link addressing paper jams in general:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09189&lc=en&dlc=en&cc=us&rule=26353&product=304535
and here's one on cleaning your printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00016484&lc=en&dlc=en&cc=us&product=304535
hope this helps a little bit for future refs. remember that using good paper helps print quality and lessens printing problems. also, when you take a stuck page out of a printer, doing so gently will help ensure little scraps of paper do not tear off paper edges and get stuck in weird spots. it some times helps to gently, manually, roll the feed rollers a full turn around in the printer, too. patience pays! -JW50
Sep 02, 2008 | HP DeskJet 3650 InkJet Printer
Machine shows "Paper Jam" error
There is a paper senser present in the paper lifting area. That part of your printer is not working properly. Replace that part and then try
Sep 20, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP Deskjet D1455 InkJet Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
