I have a Trane xr12 air conditioner. I turned off 230v breakers at the air handler, cleaned the filter and turned the breakers back on. now the compressor doesnt come on. I checked the relay on the compressor, and if i close it manually it turns on but cant figure out why it isnt closing automatically. obviously not getting voltage. was working before i played w/ breakers. Also getting good 250v across all breakers. could i have lost a sensor or something/
  • Robert May 28, 2011
    Are you refering to tje contactor coil not energizing on the outside compressor?
  • 413 Answers
Is the blower coming on inside? If it isn't, try tripping both breakers again. If the blower is working, your thermostat may be timed out or the air cond may have a timer in it that will keep it from coming on for a few minutes.
If none of the above work, make sure you didn't pull any wires off when you pulled the filters out.
Posted on May 28, 2011
Error code 91.03 on a trane tzone 950ac52za
Turn breaker off to air handler for 10 seconds, then back on. Give time to initialize and see if error clears. If not go into technician access to diagnostics. I believe in there you will find summary table. SUMMARY TABLE is what you need. Whatever is "offline" is the problem. Delete that item and go from there.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Dec 19, 2016 | Heating & Cooling
Why did the air handler on my 1999 Trane heat pump stop working? Could it be a fuse in outside unit
The fan is controlled by a relay that is operated by the thermostat. There is usually a wiring diagram inside the unit that will show the location of the relay.
Feb 08, 2015 | Heating & Cooling
Problem with Air Conditioner
there will be an access panel where the motor is located. 1st thing to check is fuse or circuit breaker feeding the air handler. this is on seperate power from compressor unit outside and usually has a fused or breakered disconnect on the side of the unit. if fuses are good or breaker is not tripped then switch fan mode to on. if blower runs in on but not in auto then it is a thermostat problem. if still no go then turn off power, remove access panel and find the squirrel cage fan blade. make sure it turns freely. it is very common for these motors to go bad. it can usually be removed easily and taken to a motor shop. I use Roy's Electric in Richmond, Va. They can test the motor on the bench and replace it if it is faulty.
Sep 08, 2012 | Heating & Cooling
Ac is set at 74 and it only cools to 80
system needs to be charged check filters and coils make sure they are clean first could be an air restriction issue to your intake
Jul 28, 2012 | Heating & Cooling
Trane xr12, fan works but compressor doesnt come on.
Check the capacitor and contactor. You may have wires burnt at the compressor terminal from corrosion.
Trane xr12 blower stays on after first cool cycle run
Hello, this is usually caused by a sticking fan relay on the intergrated comtrol board. You may be able to tap on it to shut it off but eventually the control board will need to be replaced.
Jun 02, 2012 | Heating & Cooling
I have a 12,000 Amcorair mini split. Air handler shut down, popped the breaker. Turned the breaker on. The air handler displays F1 fault code.
Hello I think F1 fault is air filter...If it is clogged it can cause iceing (on the coil) and will trip a breaker.Give a good clean/wash or replace.
Jun 04, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
No heat on trane XR12 heat pump
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Dec 25, 2010 | Heating & Cooling
Trane Air Conditioner air handler drips water
are you still having issues with your twg030a140b1? the heatpump that you own should not be having this issue the question is the configuration of the coil in the AHU is it properly installed. I am a distributor for Trane equipment and am wondering if the install tech installed correctly
May 30, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Apr 28, 2009 | Heating & Cooling
Heating & Cooling Logo
279 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
