Question about Cameras
Well when i take a picture, it takes it. but when i try and take another picture, it just beeps three time. and then i tried to turn it off, and it wont do that either. it just says "please wait for your camera to finish recording" but im not recording anything. and i waited for a bit to see what happened. and all it says not is "system error" in red. the only way to turn it off is to take the battery out. i tried to reset it. but nothing is working...
  • 3 Answers
Sounds like you have a bad camera,
try to take it back to the store you got it from and tell them what is going on,
be careful thou as people are getting stupid nowadays.
Posted on May 28, 2011
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
MACHINE WILL NOT INITIALIZE RIGHT OUT OF THE BOX. JUST BEEPS
Make sure the switch is on REG mode. Make sure there are NO batteries in it. Turn power off at wall for a few minutes. Turn on and it should beep three times. Then put the batteries in. If it beeps more than three times, the printer is probably jammed or faulty. Make sure it can turn. Try taking the ink roller out as it sometimes gets sticky and jams the printer.
Mar 23, 2016 | Sharp XE-A101 Cash Register
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Is the camera suspose to beep when taking a picture?
yes it is sposed 2 beep when you are takin a pic. too tell u its done taking.
Dec 26, 2008 | Disney Pix Micro Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
Cameras Logo
134 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
