Question about Canon PowerShot A570 IS Digital Camera
My camera does not keep battery life. It keeps telling me to change the batteries and I have only taken several pictures with a new battery
  • 3 Answers
Sounds like you have a bad camera,
try to take it back to the store you got it from and tell them
Posted on May 28, 2011
  • wesford May 28, 2011
    this is an obvious solution. I have discovered other solutions
Tip
Canon BP-511 Battery Maintenance Tips
battery info via:
http://www.sales-battery.com
http://www.global-battery.co.uk
Canon digital cameras come in several different lines, some compact for easy travel and quick pictures, and others larger with multiple lens options and more power. the same problem many users have to encounter is the battery.manufacturers will tell to them how numerous hours that Li-ion notebook battery can last, however, they don't tell you how to maintain the battery.
There are more tips for you to change a common battery life, extend it for digital camera. One more simplistic method of increasing the lithium ion battery life by defragmenting the disc and remove excess folders. The suggestion for keeping your device for canon digital camera run powerfully with the hi-capacity canon bp-511 battery, which is a replacement battery, can be used recycled.
A lithium-Ion battery for canon bp-511 has internal circuit board with chips that allow it to communicate with the digital camera to monitor battery performance, output voltage and temperature. It also gives the notebook much more accurate 'fuel gauge' capability to determine how much battery runtime is left before the next recharge is required.
The battery for bp-511 battery provides uninterrupted reliable performance for the canon digital camera no matter you are on the trip or on the train travel, and want to record the sight.
This least quantity of time draws a considerable effect on the complete replacement battery life existence, the lithium ion bp-511 battery is 1600mAh, in fact if the battery can be used correctly, the performance of the battery can be used as the original battery, just depends on yourself. When in the hibernate mode in & out are extremely favorable and efficacious than the usual start & shutdown operation.
Talk about the battery storage, storage the battery in the normal temperature. When in hibernate mode the shutdown procedure grants a alternative to pause present work immediately with the power-off and when in start up activity it will keep on with in a few seconds entirely, As a result hibernate mode saving power. Do not modify or disassemble the canon digital camera battery under any circumstances.
Do not store a replacement battery pack near chemicals and in a damp area as this will reduce Notebook battery ability. The replacement battery is made with chemical material, take care of it, if you can.
more canon camera batteries discount now,like
Canon nb-8l Battery US $ 10.54
CANON NB-5L Battery £ 8.58
CANON NB-4L Battery US $ 6.71
CANON NB-3L Battery US $ 6.71
CANON NB-2L Battery £ 8.48
CANON np-e3 battery £ 21.52
on Jun 04, 2010 | Cameras
Repair
If you are using standard or "Heavy Duty" batteries, this is not unexpected. Try Alkaline or even better, rechargeable NiMH batteries, they have a much longer life. Some of the earlier digital cameras were real power hogs.
Hope that helps,
Bax
Jun 16, 2013 | Pentax ZX-30 35mm SLR Camera
New batteries are not lasting longer than a day
Battery life can fluctuate greatly from day to day. It all depends on the type of photography you are doing. For example, on one day, you spent the day taking pictures outside in the sunlight, with no flash, and didn't use your camera's screen to review any of the pictures. The next day, you spent the day inside, taking lots of pictures using the flash, zooming in and out on people's faces and reviewing the pictures using the camera's screen.
Features like the flash, zoom, LCD screen and image stabilization (IS) use a great deal more battery life than if you were to not use any of those features. This could explain why it suddenly seems like the batteries aren't lasting more than a day.
However, if your photography habits have not changed enough to potentially affect battery life, there could be an issue with either the image stabilization hardware or the standby mode of the camera. If the image stabilization (a fully mechanical feature) is malfunctioning, it could be activating when it shouldn't be, such as when the camera is on but you aren't about to take a picture.
I would try testing the camera by taking pictures using different camera settings.
  1. Turn off the flash and image stabilization, use the viewfinder instead of the LCD live view mode, do not zoom in or out. Take as many pictures as you can before the batteries die.
  2. Keep the flash and image stabilization on, use the LCD live view mode, use the zoom frequently. Take as many pictures as possible before the batteries die.
With test #1, you should see much better battery life than with test #2. If you still experience decreased battery life either way, there may be a hardware issue with the camera. Should this be the case, contact Canon Support to find out whether or not your manufacturer's warranty covers this problem.
Mar 01, 2011 | Canon PowerShot SX20 IS Digital Camera
I have got Digimax S600. The video is ok but in the stills there are vertical lines/stripes. The pictures taken outside are so bright that one can't make out any thing.
Possible fault in the CCD( charrge coupled device) of the imager in the camera as it is not adjusting the AGC.
Since this is a delicate section the fault must be checked and confirmed with Samsung.
Remove off the battery and keep aside overnight. replace and check. Similarily keep the set on for several hours to see if the picture corrects the light balance.
In there is some change also the board is faulty..
Sep 11, 2010 | Samsung Digimax A7 Digital Camera
Camera says replace batteries even when fresh ones are installed
Sir/Maam,
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
Keep me update, hope i helped you. Thanks.
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
Camera won't stay on
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jul 15, 2009 | Canon PowerShot A510 Digital Camera
Camera shuts down in shoot mode but I can view pictures on card no problem
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera. The Canon A4XX series are particularly sensitive to poor quality batteries. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Aug 23, 2008 | Canon PowerShot A430 Digital Camera
Change batteries message
Are you using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pics in today's digital camera. Some brands may have reached their shelf-life in the store, and may have problems just powering startup of the camera right out of the package.
Digital cameras for the most part should only be used with rechargeable NiMH batteries. These days many retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many, many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Aug 01, 2008 | Canon PowerShot A460 Digital Camera
Change battery message
I am experiencing exactly the same problem with my Canon Powerhot S2IS. I tried the same thing to remedy it by cleaning off the contacts, but no luck. And it's not simply a cold weather problem. My camera does this with brand new Duracell batteries as well as with freshly recharged NMH batteries. What gives? I've had the camera for nealy 2 years and have taken excellent care of it.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
