Question about Dell Inspiron 1521 Notebook
Laptop screen turns off and keyboard freezes just minutes after i turn it on
  • 1,555 Answers
You need to hit f8 while booting up and select last good know entry and enter every thing will be normal
Posted on May 28, 2011
  • 54 Answers
Check the power source and make sure the cooling fans are not clogged with dust and lint. Laptops will just shut down if they are over heating or not getting enough power.
Sony vaio nb laptop touch screen freeze
Hello Adnan eickov
Pls go to start menu and select screen calibration option. and re calibrated.
Mar 05, 2014 | Computers & Internet
Keyboard on laptop A52 joybook somtime not working
your product is overheating, because of the cooler fan cant push air in the cooler cells, your computer is overheated because its jammed with dust and should be cleaned out of a tech-man
Jan 21, 2014 | BenQ T2370 Notebook
I have an msi motherboard b75 ma g43 when i turn my system on the screen freezes at 99 appearing on the botoom right side corner of my screen.my mouse and keyboard are also not working.
Check your RAm and that you have the keyboard connected to a working port. A modern computer will not start(usually) without a keyboard. If your keyboard is a USB one then plug it into the front.
Jul 24, 2013 | Computers & Internet
P875 satellite keyboard
Do the key lights flicker when on freeze stage? I had such a problem with my keyboard, it died after around a month :(
Apr 12, 2013 | Computers & Internet
Asus k53e keyboard freezes and then fan blows out hot air
sounds like it's overheating turn over after shutting down and look to see if there's clogged vent for fan
use a plastic tip on vacuum to get dust out then try it again
May 22, 2012 | ASUS K53e B1 Notebook
My touchpad on my hp pavilion dv6-1245dx keepss freezing
if ur connecting ur touch pad with a cable to ur laptop check for the cable wire compactibility
Mar 08, 2012 | HP Pavilion dv6000z Notebook
Unlock keyboard on computer
Hello. There are several things you can try to unlock the keyboard.
- Shutdown the computer, then turn it on afterwards. Check keyboard functionality.
- If you're using a desktop, disconnect keyboard, restart computer then plug the keyboard back once the computer has boot up completely.
- If you're using a laptop, turn it off, unplug the power cord, remove the battery, re- seat the battery after a minute, plug-in the power cord then turn on the laptop.
- Disable On-Screen keyboard
- Right click "My Computer" icon on the desktop then select "Properties". Click "Device Manager". Look for the Keyboard, hit the drop down arrow beside it to display the installed keyboard. Right click on it and if you see "Enable", click on it, otherwise it's already enabled.
Nov 26, 2011 | Dell Computers & Internet
Computer Freezes unless pressure applied
With the laptop turned off, take out the hard drive completely from the laptop and then reseat it back into its slot and make sure its nice and snug.
Then go ahead and turn it on and see it will run without freezing on you and having to apply pressure on the keyboard.
If that doesn't work then disconnect the keyboard and see if it will run smoothly without the keyboard. If it does then you might have a stuck key on the keyboard that is making the unit freeze so you might have to replace the keyboard.
Jul 06, 2009 | IBM ThinkPad T43 Notebook
Gateway 460 freezes or will not come on.
It's probably overheating that's why when you first turn it on it works fine up until a certain point. Does it feel hot on the bottom? Are the fans spinning?
Feb 19, 2009 | Gateway M460 Notebook
Fujitsu laptop 6240
You can connect an external keyboard and see if the problem persists. That would rule out a keyboard problem. Also connect an external mouse to see if the system is frozen or the keyboard/mouse combo are just not working. If its a keyboard problem, chances are you either spilled something on it or the connector came loose from vibration or general use. Unscrew the keyboard and reseat the cable. See if the problem is resolved.
Aug 17, 2007 | Fujitsu (G281065802)
Dell Inspiron 1521 Notebook Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
