Question about Lakewood Oil-Filled Electric Radiator Heater
Oil is leaking from the heater. can it be saved or do i get rid of it
    Brigadier General:
  • 4,736 Answers
There are some "experts" on here that would tel you it can be repaired. And certainly, the leak could be repaired, but refilling the heater with the correct oil and in the correct amount, is a **** shoot at best. I look at it this way ... If it leaked once, it's going to leak again, in a different place. So, it's really not worth repairing. Get a new one.
Hope this helped you. Please let me know. Thanks.
Posted on May 29, 2011
Tip
Oil Filled Radiator Heater Leaking
<p>A very common and increasing popular source of <b>supplemental heat</b> in the last few years has been the <b>oil filled electric radiator. </b> <br /> <p>These <b>radiator heaters</b> are filled with an oil that circulates through the fins of the heater and is heated by <b>electric heating elements</b>. The result is a steady even type of heat that has a lower surface temperature then many <b>space heaters</b>, making them a great way to get <b>supplement heating</b> into a room when you have pets, small children or combustibles near by.<br /> <p><br /> <br /> <p>One of the big questions that comes up with these <b>oil filled heaters</b> is what to do if they start to leak. The answer is that if the<b> oil heater</b> starts to leak then it is no good anymore and needs to be disposed of. These<b> heaters are filled with oil</b> at the factory and then are sealed tightly. Because of this there is no need to ever <b>refill the heater with oil</b> again. The heaters are sealed with the proper oil inside for the <b>best heating efficiency. </b> <br /> <p><br /> <br /> <p>So what this means is that if you have one of these <b>oil filled radiator heaters, </b>you will never have any <b>maintenance</b> or worries about <b>adding oil to the heater</b>. But if there ever is a leak then the heater is also no good and will need to be throw out and replaced. Very few of these <b>oil filled heat units</b> ever leak, but as is always the case there are always some that do.<br /> <p><br /> <br /> <p>A word of caution about heating efficiency. Always remember that when <b>heating with electricity</b>, the <b>laws of physics</b> always apply. <b>For every 1 KW of electric you will only ever get 3415 BTU's of heat.</b><br /> <p>There is no way to get any more or any less than that, so if anyone tries to tell you that their electric heater is more efficient then the next one they are not telling the truth.<br /> <p><br /> <br /> <p><br /> <br />
on Jan 12, 2011 | Heating & Cooling
Burning smell oil
Have you checked for oil leaks? Valve cover gasket or gaskets if a V6 would be the most common oil leak. Only with heat or have you tried with a/c ?
Apr 09, 2014 | 2004 Dodge Stratus
1 yr old heater leaking small amount of oil. Can I repair at home ??
Unless you're a welder. I don't think so. In addition, ALL the oil will have to be drained from the heater and then replaced, which could be a real headache. Personally, I wouldn't undertake it as a DIY project, with the expectation of success. Check to make sure, the heaters not still under warranty, as this leak is a manufacturing defect. Unless, you did something to cause the leak.
Hope that helps answer your question,
Mar 16, 2011 | Pelonis Oil Heater HO 157
How does one refill lakewood heater ?
These are sealed oil heaters and do not require refilling, if yours is leaking then it is bad and should be disposed of. They should not use oil or leak oil ever.
Dec 28, 2010 | Lakewood Oil-Filled Electric Radiator...
I have a oil filled rad style electric heat ,which is leaking oil can it be fixed? If so how.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
heatman10
Dec 19, 2010 | Honeywell HZ-709 Oil Filled Radiator...
Our HoneywellHZ-690 oil - filledheater is leaking and I want to know if it is safe to use.
heatman101
Dec 03, 2010 | Honeywell HZ-680 Oil Filled Radiator...
Pelonis HO-0128 makes strange noise
Nothing wrong with it. This is a normal sound made as the oil heats. As the heater heats up, the sounds should subside.
Nov 19, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Lakewood Oil-Filled Electric Radiator Heater Logo
448 people viewed this question
Top Lakewood Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Paul Carew
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
