Question about Cycling
I Have a Magna Mountain tamer 15 speed bike and i need the manual for it.
  • David Dunn
    David Dunn May 28, 2011
    What in particular do you need to know? There is nothing on that bike that is unique to it.
    Except for proprietary frames or technologies, everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the individual manufacturers' websites.
    Search engine queries will bring you instant answers for how-to do just about anything to or on it.
I need an owners manual for a Magna Mountain tamer bike a 15 speed womens
Posted on Mar 01, 2013
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: need a bearing size or
Pedal bearing or bottom bracket bearing? Your best bet would be to take it to a local Bike Shop and have them assess it.
Posted on Aug 05, 2010
Testimonial: "Thank you"
Can anyone tell me where I can find/download an owner/repair manual for the Magna Glacier Point 12-speed 26-inch bike that my husband rides? it would really be helpful for him.
No, it probably would not be helpful. Bike owner's manual have very little useful info in them. They are generic, not specific to one bike and comprise mostly safety information. Good repair and other guidance can be found at Sheldon Brown Bicycle Technical Information, and Repair Help and Education has great repair information YouTube is less reliable but a good secondary source.
If there is a bike co-op in town or a bike shop offers repair classes that is even better. Bike clubs also sometimes offer beginner classes or rides.
Jan 15, 2017 | Magna Cycling
Found bicycle cerial# 97td639265 is it stolen
contact your local police stolen property department and have it checked
Aug 11, 2015 | Magna Men-s 26 In Speed Charger Bike
Magna great divide
The Magna Great Divide does not have a quick release lever on the rear wheel.
Aug 02, 2014 | chitech Magna Womens Great Divide 24"...
1997 Honda Magna 750 Stalls
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
2000 Magna stalling when hot
Starts choke but dies with little throttle
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Apr 16, 2013 | 1997 Honda VF 750 C Magna
How do i adjust mountain bike brakes
There is a small tension nut on the cable near the brake calipers on the cable coming from the brake. Loosen that nut and squeeze or loosen the brakes to where you want them and then retighten the nut on the cable.
Sep 08, 2012 | Magna Women-s 28 In Cityscape Bike
How many links should the chain be for proper length on a 26" dual suspensin magna excitor 21 speed mountain bike
That is subject to the individual bike and the sizes of the chainrings and cassette cogs. No simple answer.
You COULD web surf for advice on "how to calculate chain size" on your own.
http://www.parktool.com/blog/repair-help/chain-length-sizing
If you avoid cross-chaining you can run a shorter chain. I never go more than one cog beyond the cassette center opposite my chosen front chainring.
Sep 08, 2011 | Cycling
I have a dynacraft magna great divide 21 speed mountain bike and don't know how to use it. There was no owners manual. I don't know anything about using the gears, could you please help'
Bikes is bikes so ANY owers manual would ge tyou through the basics.
TRy Huffy's. http://www.huffy.com/Support/OwnersManuals.aspx
Then, using a search engine, ask any question like "how to shift a bicycle" and videos will appear instantly.
This doecument will teach you a whole bunch of stuff about techniques and strategy for road riding.
http://www.johnforester.com/BTEO/ECIL.pdf
Jul 03, 2011 | Cycling
What type of mountain bike are they?
There are six main types of mountain bikes. These include: comfort, hybrid, hardtail, single speed, full suspension and freeride. One of these types of bikes will fit your style and riding needs. Talk with a bike salesperson to determine which one will work best for you.
Dec 16, 2010 | Cycling
I need an owners manual for a roadmaster mt storm by huffy
The best I can do is to provide you with the manual that Huffy provides for multiple bikes. The manual below is for multi-speed and freewheel bikes.
Huffy Multi-speed Manual
Hope this helps. Thanks for using Fixya.
Note: If the manual link above is not useful you may contact Huffy directly at:
Huffy Bicycle Company
6551 Centerville Business Pkwy
Centerville, Ohio 45459
(800) 872-2453 customer service
Monday - Friday: 8:00AM - 12:00PM; 1:00PM - 4:30PM EST
Jul 13, 2010 | Huffy Men Mountain Bike (26")
Cycling Logo
576 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
