Question about Dacor Epicure EOG36 (LP) All-in-One Grill / Smoker
Trying to replace igniters. is there an easy way to get to them to replace? or do you have to chisel out screws or easy out?
    Brigadier General:
  • 4,736 Answers
I know, it's a bear, once the grill is a few years old. Aside from that, you'd expect the R & D Dept to come up with a better way to attach the 'U' shaped burners, for a grill that is one of the most expensive ones on the market.
In any event, I found that if the screw heads are badly rusted, using an easy out or drilling the screw out, is about the only way to do it. If you drill it out, start with a small diameter bit and work your way up. Of course, you'll have to use a little larger diameter sheet metal screw to attach the new burner(s). I highly recommend Stainless Steel Screws, in case you ever have to replace the burners again.
Hope this helped you get them out. Please let me know and Happy grilling!!
Posted on May 29, 2011
How do I replace the ignition switch on my 74 MGB
After removing the column covers, (screws in holes underneath) The 2 unslotted studs holding the ignition and steering lock assembly onto the column are anti-theft screws. They will turn by hitting them on the edges with a hammer and small sharp chisel - counter clockwise.
Feb 12, 2014 | OE Aftermarket 1963 - 1974 MG MGB...
How to remove ignition cylinder without key
Hi MCC, You will need to remove the plastic cowling from around the steering column by removing the screws from its underside. Tilt the steering wheel down (if fitted with adjustment) and remove the cowling covers. Disconnect the electrical sockets and then with a cold chisel knock out the four blind bolts. Once the blind bolts are removed the switch and barrel will be easy to remove, unless the lock has activated, in which case a little force may be required to remove the release the locking tongue. However if you can get a good locksmith, who knows the job, a replacement key can be made without removing the barrel. Regards and happy new year, John
Jan 06, 2013 | 1989 Honda Prelude
Removing and replacing a carburetor idle mix screw with stripped head
Reverse drill bit might work. And yes they do make easyouts that small.
May 14, 2017 | 2007 Suzuki Boulevard S40
Law mower screw stripped and blade can't be removed
this can be a real pain in the rear to deal with...are you sure you want all the drama?...find a way to bind the blade so that it won't rotate at all.....now get a pair of vice grips on that nut and try to loosen it......if the threads itself on the threads are stripped as you described, then you'll have to drill out the screw....meaning you'll have to find dead center and mark it with a heavy duty punch, then use a cobalt drill....1/8th inch to start with, then get a slightly larger bit.....at some point you should be able to chisel the head off the bolt and remove the blade.....now you'll have to easy-out the stripped screw from there......once the stripped screw is out....you'll have to determine whether there is enuf material left to drill and tap to a larger diameter bolt/screw.OPTION 2..you may be able to get a puller from the auto parts store.....but you could ruin the threads even worse than the condition they're in now.OPTION 3....get a good grip on the bolt head with vice grips, then get a buddy to tap a cold chisel horizontally between the bolt head and the blade, tapping easy while you pull up counter clockwise on the vise grips and see if the bolt screw head starts to back out at all.....if you may no progressOPTION 4.....if you have the room to do it...hacksaw the head of the bolt off, remove blade, now try to remove the screw with an easy-outand drilling good luck with this one.
please post back what you tried and results
Apr 27, 2012 | Garden
Need to replace ignition cylinder. no keys
This is not an easy repair due to anit theft requirements. need to chisel off bolts.
Section 11-04: Steering Column 1997 Probe Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/17/2000
Ignition Switch Lock Cylinder Removal
  1. Remove the steering wheel (3600). Refer to the procedure in this section.
  1. Remove the four lower steering column shroud screws.
  1. Separate the upper and lower steering column shrouds.
  1. Remove the ignition switch lock cylinder illumination miniature bulb from the lower steering column shroud.
  1. Remove the upper and lower steering column shrouds.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal and installation procedure.
  1. If equipped, remove the ignition/shifter interlock cable screw.
  1. Disconnect the ignition/shifter interlock cable (3F719) from ignition switch lock cylinder (11582).
  1. Use a chisel to remove the two ignition switch lock cylinder bolts.
  1. Remove the ignition switch lock cylinder from the steering column.
  1. Disconnect the ignition key reminder switch electrical connector.
  1. If necessary, remove the ignition key reminder switch.
Installation
NOTE: Use new ignition switch lock cylinder bolts. Tighten the bolts until the bolt heads break off. Check for proper ignition switch (11572) operation.
To install, reverse the removal procedure.
Mar 25, 2011 | 1997 Ford Probe
Hi, i have 1991 mazda protege. I accidentally broke my key in the ignition lock and now i was wondering how do you take off the ignition lock cylinder? p.s key was pretty worn down already
Ignition Switch/Lock Cylinder REMOVAL AND INSTALLATION CAUTION
Some models covered by this manual may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Section 6. The ignition lock is an integral component of the steering lock mechanism. If the ignition lock must be replaced, perform the following procedure. Fig. 1: Exploded view of the ignition switch/lock cylinder assembly 89548g14.gif
Fig. 2: Remove the break-off head retaining bolts by chiseling a slot in the bolt, then removing them with a screwdriver 89548g15.gif
Millenia
  1. Disconnect the negative battery cable.
  2. Properly disarm the air bag system.
  3. Remove the rear console box, brake boot and center panel (disconnect the harness connectors).
  4. Remove the rear console.
  5. Remove the undercover, glove compartment and compartment cover.
  6. Remove the upper and lower steering column covers.
  7. Tilt the steering shaft down. Remove the cap and panel light control switch. Remove the meter hood mounting screws. Pull the meter hood forward to disengage the clips.
  8. Remove the instrument cluster,
  9. Remove the drivers side air bag and the steering wheel.
  10. Remove the combination switch.
  11. Remove the passenger side air bag mounting bolts, electrical connector and remove the air bag module.
  12. Remove the hood panel release lever. Pull the side panel forward to disengage the clips, remove the side panel.
  13. Remove the side covers.
  14. Remove the dashboard mounting bolts, pull the dashboard up and forward and remove.
  15. Remove the steering shaft.
  16. Remove the screw and the ignition switch and disconnect the ignition switch connector.
  17. Using a chisel and a hammer make a groove in the heads of the steering lock mounting bolts. Remove the bolts and the steering lock assembly. To install:
  18. Install the steering lock mechanism to the steering column jacket. Make sure that the lock operates correctly. Install new mounting bolts and tighten the bolts till the heads break off.
  19. Reconnect the ignition switch connector to the ignition switch and install the ignition switch to the steering lock mechanism with the screw.
  20. Replace the dashboard close to its mounts and connect all harness connectors. Install all mounting bolts. Torque to 14-18 ft. lbs. (19-25 Nm).
  21. Install the side covers.
  22. Instal the side panels.
  23. Install the steering shaft and torque the mounting bolts to 12-16 ft. lbs. (16-22 Nm).
  24. Connect the passenger side air bag module electrical connector and replace the module to the dash and install the mounting bolts.
  25. Install the combination switch on the steering column.
  26. Install the steering wheel and drivers side air bag module.
  27. Install the instrument cluster.
  28. Install the meter hood.
  29. Install the upper and lower steering column covers.
  30. Install the glove compartment cover, compartment and the undercover.
  31. Install the rear console, bracket, center panel, brake lever boot and the rear console box.
  32. Reconnect the negative battery cable,
  33. Place the steering column securely on a workbench. Use a chisel and hammer to make slots in the head of the lock screws. Remove the screws.
Except Millenia
  2. If equipped, disarm and remove the air bag.
  3. Remove the steering wheel and the combination switch.
  4. Remove the steering column by performing the following:
    1. Remove the driver's side under dash covers.
    2. If equipped, disconnect the key interlock cable from the steering column.
    3. Detach any remaining electrical wire harness connectors from the column.
    4. Remove the upper column-to-dash mounting bolts. Support the steering column.
    5. Remove the intermediate shaft-to-steering column shaft coupling bolt and remove the steering column-to-firewall bracket bolts/nuts.
    6. Remove the steering column from the vehicle.
  5. Place the steering column securely on a workbench. Use a chisel and hammer to make slots in the head of the lock screws. Remove the screws.
  6. Remove the ignition lock assembly. To install:
  7. Position the ignition lock and bracket on the steering column.
  8. Install the new screws until the head twists off. Make sure the lock operates properly while tightening the new locking screws.
  9. The remainder of the installation is the reverse of the removal procedure.
Feb 12, 2011 | 1993 Mazda Protege
Trying to take negative clamp off battery, pos came off easy. seems to turn after i took the bolt off but just will not open enough to release off the battery. any ideas?
using a screw driver or chisel, find the small line where the battery clamp is joined in half. Put the screw driver or chisel on this line and strike with a hammer firmly. This will spread the clamp out. Also soak it in CRC or similar. You can also use the screw driver as a lever underneath the clamp. Ensure the positive lead is well away from where you are working. It is a good idea to wrap both the positive lead and positive terminal in masking tape to prevent any arcing out.
Jan 23, 2011 | 2003 Land Rover Freelander
Replace ignition switch
REMOVE THE PLASTIC COVERING FROM THE STEERING COLUMN UNDER THE STEERING WHEEL. YOU PROBABLY WON'T HAVE TO REMOVE THE WHEEL. THERE SHOULD BE SCREWS ON THE BOTTOM SIDE OF THE PLASTIC PIECES . THE SCREWS THAT HOLD THE IGNITION LOCK CYLINDER IN PLACE MAY HAVE SECURITY HEADS, [ROUND , NO SLOTS OR HEXES] YOU WILL NEED A SMALL CHISEL & A SMALL HAMMER TO START THEM TURNING.
IF YOU ONLY WANT TO REPLACE THE ELECTRICAL PART, " THE BLACK PLASTIC WITH THE WIRES " ALL YOU HAVE TO DO IS REMOVE THE SINGLE SCREW FROM THE OPPOSITE END WHERE THE KEYS GO & PULL OUT THE PLASTIC SWITCH.
Jan 09, 2011 | 1993 Isuzu Trooper
2004 GMC Sierra CV half shaft problem
They come off really easy just take a sharp chisel and a hammer and put the chisel between two of the teeth on the abs ring and hit it fairly hard but you don't have to hit it with alot of force just repeat till the ring splits then tap it off with a the chisel or screw driver it will come off really easy after it is split.
Sep 01, 2009 | 2003 GMC Sierra
Trying to replace ignition, trying to remove the old ignition.
This is not hard to do, first remove all the steering column plastic, then you'll see two bolts with no heads on them. Take a chisel and a hammer and loosen the bolts, counterclockwise. Install the same way except the new lock assembly will have reverse hex screws you torque down until the heads break off. good luck.
May 27, 2009 | 1994 Honda Civic
Dacor Epicure EOG36 (LP) All-in-One Grill / Smoker Logo
185 people viewed this question
Top Dacor Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Dacor Grilling Expert? Answer questions, earn points and help others
