Question about AEG D2100-4 Electric Double Oven
Oven wont' work regardless of proper installation
  • 24 Answers
Hi Have you set the clock The way to do this is in the manual if you dont have a manual you can get one here http://www.manualsmania.com/download.php?link=65af94c83ee1528c47d230faaa77ad4c9697 Regards Geoff Stove Recyclers
Posted on May 29, 2011
I have Thermador double oven. It wouldn't heat up (top and bottom). I replace Control board and digital display. Now the bottom oven heats up but the top one still not working. Could you pleas
Double check each connector to be sure it is installed (aligned on pins) properly. Also check wiring diagram for a safety limit thermal switch. If it has one, push to reset it.
Jan 16, 2015 | Thermador SC302T Electric Double Oven
Kenmore 790
I could be wrong, but from your limited description I am assuming that you cut the cord and wired direct to the box. You may not have 240 volts at the box and are trying to connect it to 120 volts. A dark green wire is the safety ground. The white is neutral and two colored wires are supply lines with 120 volts ( average) EACH. Better get someone in there that knows electricity and how to make proper connections to the proper voltage. Otherwise you are asking for major trouble.
Jun 26, 2013 | Ovens
Both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
First try a layer of silver paper around spindle.
If not satisfactory then try a "No nails" type of clue.
Jun 04, 2012 | New World E90DOa Electric Double Oven
KGHST307HBS6 bake cycle does not heat up, no gas smell, broiler still works, ignitor glows about as bright as the broiler ignitor and was recently replaced. The gas valve recently replaced and no smell of...
you have 2 posibilities the first one is very unprobable and the second will fix the oven
1) the new gas valve is defective and while the proper amprage is being supplied to it,it simply wont open
2) even though the bake ignitor is indeed coming on it isn't drawing the proper amp draw (3.2-3.6 amps) to open the gas valve ,the very fact the ignitor comes on totally eminates that the control isn't providing power to it for the bake ignitor to heat
i have been a appliance repair technician for over 30 years and am 100% confident that by replacing the bake ignitor the oven will work fine
Jul 20, 2011 | Ovens
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
My electrolux EOB5610 wont heat up....the fan works and the grill works but will not reach any sort of temp !!!!
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 02, 2011 | Electrolux EOB5610 Ultrafan Electric...
Hi i have a Samsung oven bf641fst the light and fan come on but the heat side wont work and the led sceen is blank?
May 31, 2011 | Viking VESO176 Stainless Steel Electric...
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
This is the model of the range, matching oven don't know the model # you cain't control the heat, you burn every thing
The make and model number and type (Gas of electric) didn't come through on your post.. regardless.
If it had been working properly.. then became erratic.. chances are the temp sensor is bad. This is the part that fails more often than the controller.. mostly because it's located inside the oven.
In the oven you will notice toward the back a usually at the top corner a long thin tube. This is the temp probe.
They are easy to test and easy to replace.
Some have to be removed from the back. This may involve removal of as few as two screws up to removing the back panel.. a fairly simple repair once you have access.
The oven should be disconnected from the power source either at the circuit breaker or outlet before attempting repair.
To test the sensor you will need a volt ohm meter. Once you have access to the connector on the sensor either by removing it or in some cases via the back panel. (the sensor must be disconnected to perform the test) it should read 1100 ohms +/- 10%.
I have seen them physically damaged as well a sure sign that replacement is in order. Depending on the age of the oven some folks just replace them to see if that's the problem.. before moving on to testing the controls.
Again.. working on any oven is dangerous so disconnect the power and shut off the fuel source before working on it.
Obviously you will need make and model number to get the part. Many appliance repair or parts centers will have this part in stock. Like elements..it's not if it will fail.. but when.
Best of luck!
Apr 20, 2011 | Ovens
Oven wont heat up, the grill does and the clock, timer works
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection. Thank you for your time and thanks for choosing FixYa.
Feb 28, 2011 | Bosch HBL 5052 Electric Double Oven
AEG D2100-4 Electric Double Oven Logo
192 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
