Question about Panasonic Home Theater System System
No Sound when AUX is on the screen...HELP
When I turned it on, it had sound for 3 seconds, then it went dead. I checked the Radio and the DVD player and it all works. There is no sound coming out when I put in on AUX.
PLEASE HELP!
  • special2usa Aug 16, 2008
    This is a panasonic SA PT750
I'm having the same problem. Have you found a solution?
Posted on Sep 07, 2008
  • sksedit Sep 07, 2008
    I think I just figured it out. You have to set
    the audio input on the receiver to D-IN instead of AUX. On your
    Panasonic DVD remote, push the "SETUP" button until you see "TV AUDIO"
    on the front of the player. Then push the down arrow. You will either
    see AUX or D-IN. You can't toggle between the two. If you see AUX,
    you need to push setup again and then push the down arrow again and you
    should see D-IN. You should hear TV audio at that point. I don't
    think they could have been any less vague about this in the instruction
    manual. Hope this helps.
Samsung HT-THX25 sound problem
I had the same problem. How i fixed ? I unplugged HT and I kept pressed the power button from DVD for a few seconds. Repeat it, put it in socket and turn it on. It happens from condensation or voltage variations.
Sep 19, 2012 | Audio Players & Recorders
Radio and CD player in Jeep not working only Aux. Can only adjust volume when in Aux mode?
sounds like you might need a new cd player, if it was a fuse the problem would be there 100% of the time
Aug 11, 2012 | Jeep 2007 Grand Cherokee Laredo
I bought a 2007 GMC yukon recently. My DVD player is in the roof. It has a wonderful picture and is operational but can not get any sound at all - not in wireless headphones or through the cars audio...
These types of dvd's are custom installs so the brand and model pf the player would have helped.
On them the sound is sent in 3 ways:
1 - usually there is a cable coming from its audio output connections to the AUX input of the radio. You will have to check the player to see if one was installed; if it has you must make sure the radio is set to use the AUX entry as a source and that the cable connecting them is intact. For testing purposes you should connect a separate amplifier to the player thru these output connectors to see if you get a sound; if you don't then the defect is in the player. Check the audio settings, if they are ok then the defect is hardware and the player will have to be taken to a repair shop.
2 - if the guy that installed it didn't wanted to bother with the hassle of removing the head liner to draw the audio wore then it has most likely just set the connection thru the FM modulator: the player has a modulator that transmits the sound thru the FM radio band; to listen to it all you need to do is to tune it at the frequency of the modulator - usually between 88 and 89.5 MHz.
3 - the headphones - very simple devices. The only thing you can check here are the settings from the player.
Dec 23, 2010 | Recoton Advent Televison & Video
Please help me enable the aux mode on the above unit, i have connected ipod to aux input, no sound as not enabled, many thanks, Pioneer AVH-P5700 DVD car stereo
Have you tried going into the menu and searching for this function?Also some car stereo's have a sub menu when the radio is turned off or in stanby mode it usually can be reached by pushing your menu button and holding for a few seconds also again the power has to be in standby mode. if this works look through menu for your problem.
Nov 04, 2009 | Pioneer AVH-P5700DVD Car DVD Player
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Auxillary 2 function does not show up on my Pioneer DEH-P2900MP
first thing you do is turn the power off on the radio by hitting the off button . there is a button you have to hold in. it should be the volume knob. if not try some other buttons. you have to hold it in for about 4 seconds. then a menu should come up. if you scroll though and you can turn on and off the aux . if you have any problems let me know
Jan 23, 2009 | Pioneer DEH-P6800MP CD Player
-Myron-Davis-Myron-Davis-AD-212
On my ad212 dvd system by Myron and Davis it has an attached fm radio modulator. It has 4 channels you can use and they corresponed to unused frequencies in the users area of travel . Mine is set to 88.7 fm and all I had to do was set the FM radio to 88.7 to get the audio playing on the dvd movie.
Nov 26, 2007 | Myron & Davis AD-212 Car DVD Player
VIDEO OK, AUDIO NOT WORKING
The aux or auxiliary is used for external audio source (ipods, portable mp3 player,etc) If you are watchig dvd movies, the sound should come from the dvd and not from aux.
May 14, 2007 | Boss DVD-2000 Car DVD Player
Panasonic SA-HT680 DVD Home Theater Sound System
when i turn my home theater system on it says f61 then it shuts off can u plz help me out here =[
Apr 18, 2007 | Panasonic SC-HT680 System
Panasonic Home Theater System System Logo
166 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
