Question about Ovens
My bad... I use my warming drawer to store of my cookie sheets. When I want to close the drawer after removing a tray, the wire cookie rack slid behind the drawer and I cannot close the drawer. I can't get under the oven or behind the drawer... help!
    Sergeant:
    Champion:
  • 338 Answers
Open drawer- use hot dog tongs and fish for rack- or a large kitchen magnet on a string
Posted on May 28, 2011
Testimonial: "Very helpful! This was something I was sure I didn't need a repairman to fix, I just wasn't sure how to go about it. Thanks a million! "
  • 1 more comment
  • marieglynn1 May 28, 2011
    There is no room for tongs - there is hardly a crack ( I can't even believe the cookie rack even fit through), I'm afraid there is no way to get to it but to remove the drawer or pull the oven away from the wall...
  • Jim Y
    Jim Y May 28, 2011
    should be able to remove drawer- empty then pull out almost all the way - tilt front up ward and gently pull out the rest of the way- even if you pulled oven- the back is enclosed
    Ah HA! It worked! YOU ROCK!
    Now, how do I get the drawer back in - - just kidding!!!
Why does my new stove, bought Feb. 2014, have a problem cooking my meats or cookies?
Read your user manual about settings and rack placement.
Also check to see if you upper oven coil is working.
Ask your appliance maker or appliance repair shop.
Did you get a warranty for your oven?
Nov 30, 2015 | Ovens
A Neff warming drawer red light flashes
There is a 'plug and socket' connector at the back of the warming drawer which does wear and eventually start to make erratic or no electrical contact. The drawer electronics read this as an open drawer and switch off the power to the heating element (flashing red light). If your competent the drawer can be stripped down and the contacts serviced or replaced otherwise consult a service technician.
Dec 07, 2012 | Neff Ovens
Top rack of cookies overcooked in a one year old Kenmore Elite 790 Electric built-in convection oven
It sounds as though the broiler element was on, causing the cookies to overcook. A bad oven temp setting switch would cause this. Set the oven to the same setting it was on for the cookie project, and check the element at the top of the oven. It should only heat when set to "broil".
murf427
Aug 03, 2012 | Stoves Ovens
The top bar on the inside that holds the racks has stopped spinning during bake.
The top bar, referred to as the "carrier" will only rotate when you start your bake cycle. If there is an issue with the rotation you should hear a steady buzzer about once every second. If you are hearing the buzzer that means the rack alignment switch isn't closing momentarily during rotation like it should be. This could be a result of a number of things, such as a bad rack switch, mis-adjusted rack switch, burned or broken wire on rack switch, bad rotation motor, rotation motor chain or sprockets fell off or are loose, or the shaft switch bar is loose (unlikely).
If you are NOT hearing the beeping then the carrier inside the oven itself could have some loose set screws and the shaft could be spinning freely inside the carrier.
Look on top of the oven and you will see a rectangular shield covering the lift and rotation assembly, remove these covers and verify if the shaft is spinning and hitting the little switch mounted near the top of the shaft.
Mar 01, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Baking on two racks - whenever I try to bake cookies on top and bottom racks, the lower tray does not bake anywhere NEAR as quickly....should I be able to bake evenly on up and down racks?
Two racks never bake as evenly as one unless you use the fan inside the oven if you have one...The fan will also shorten the baking times...
The other thing that I would check is to make sure that the lower element in your oven is not blown and you are heating with the top element only...
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My baxter rotating tray oven is not baking cookies evenly. The cookies on the outside of the cookie sheet are over-done and the cookies in the middle of the cookie sheet are not done ??
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Jun 14, 2010 | Baxter OV300E Stainless Steel Electric...
How do i change the element on a whirlpool akz452?
Turn the power OFF to the oven. Remove the oven racks. Unscrew the element where it enters the back wall of the oven from inside the oven. Carefully pull the element leads out of their respective holes. Carefully because the wires will be short.
Remove the wires from the element terminals. Place the wires on the replacement element. Reinsert the terminals into the holes and replace the mounting screws. Turn the power back on and bake me a dozen cookies.
Oct 31, 2009 | Whirlpool AKZ159IX Oven
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Bought 2nd hand--then realised it came with metal '' turntable''.??
Many lets say higher end microwaves use metal trays to improve cooking performance and are often used in conjunction with broilers in the oven cavity. Contrary to popular belief, metal in a microwave is not a problem as you may notice the racks and the cavity itself is metal. Arcing occurs when there are bare metal surfaces adjacent to each other. So a spoon usually won't cause a problem, but a fork will due to the proximity of the forks teeth. If the unit is working properly, just enjoy it.
Mar 21, 2009 | Ovens
How to clean after an oven fire
Cheryl,
If you can't scrape the plastic off then heating it up to soften it is about your only choice short of putting it back in self clean with a fan in the nearest window blowing outside to evacuate the smoke. Depending how bad it is and how cold it is where you live, you might even try freezing if off. Get it as cold as possible and see if the cold makes it easier to chip off. As far as the element, I suggest turning the oven on and letting it smoke and burn clean. Shouldn't be a very long process since the element will get hot so fast the plastic will drip off right away.
Hope that helps... Brian
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
323 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
