Question about GE Spacemaker JVM1640SJ Microwave Oven
Hot Spots in my Spacemaker Microwave Oven JVM14OH001
I need a new mixing plate for GE Spacemaker Microwave Oven MDL #JVM14OH001
  • 1 more comment
  • mj1929 Aug 18, 2008
    I do not believe the part we need is plastic. It is a small part that fits on a medal circular plate in the top middle of the mircowave oven. Need price on this part.
    mj1929Aol.com
    I ment to say the part is not cermic it is plastic.
    [email protected]
  • William Miller
    William Miller May 11, 2010
    The model should be JVM140H01.
    By mixing plate do you mean the ceramic plate? If so, the part number is WB39X75 and you can get it here.
    Does this answer your question?
  • GE Master
  • 9,174 Answers
Okay, I see now.
That would be the "stirrer blade assembly" part number WB2X9935.
It comes as an assembly, with the stirrer blade and what looks like a coupler.
GE sells it for $98, but you can get by searching for part # WB2X9935 here for only $55.61.
Posted on Aug 18, 2008
6ya staff
SOURCE:
How can I remove a GE Spacemaker Microwave JVM62
Some older microwaves slid off the mounting plate. Try pulling it forward and see if it slides off. Some of them had screws that screwed into the back plate. Remove the grill panel and see if there are screws on each side.
Aug 25, 2014 | GE Your Spacemaker Microwave Oven Model...
I have a GE spacemaker. It releases electric volts when is turned on . Needs to be changed or can be repaired?
Do you mean "sparks" inside the oven cavity when it is operating ?
If so, check for grease spots on the wave guide cover or scratches on the oven liner. Scratches can be touched up with touch up paint and wave guide cover`s can be replaced.
Hope that help`s, good luck.
macmarkus :)
Feb 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat up after something caught fire.
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
May 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
GE Profile spacemaker stopped heating all of a sudden everything else works. vent turning plate etc.Model # JVM1660CB Serial # F2909188S should I fix or buy new one...and which is the new model?
You may have a fuse that burned out. not everything runs on the same circuit . If its not the fuse than its probably the mega-tron, and that's big money. Check the fuse first. good luck DFD
Apr 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can I temporarily run the microwave without the plate rotating?
Probably not. The plate turns to make sure the food gets cooked evenly. You can take the plate out if you need a stationary object in the oven.
Feb 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker appears to be sparking inside/top
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hello
you would need to take the door apart. however by doing that you will cause more damage than just lettin it be unsightly. if the mw is 5 yrs or older wait for it to break and get a new one
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Mar 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
188 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
