Question about Endless Summer 2009 Open Flame Patio Heater
My Blue Rhino Endless Summer infrared patio heater will light, but after a few minutes, it will go out. I suspect the thermocouple. I took the entire heater apart, removed some dead wasps, dirt, etc. Reassembled and it would light, but after a few minutes, would still go out. So, I still suspect the thermocouple. I need a reference to where to buy a thermocouple replacement unit, and/or maybe a complete new pilot assembly, and/or maybe a replacement burner unit if not too much more expesive (so I don't have to disemble and reassemble).
    Brigadier General:
  • 4,736 Answers
You can purchase all need parts from Uniflame (a division of Blue Rhino) by calling Customer Support
800.762.1142. Have you model number handy when you call.
Hope this helped you.
Posted on May 28, 2011
Pilot light won't stay lit when I let go of the igniter knob. Flame is yellow and long.
Sounds like the Thermocouple has failed and needs to be replaced. It's not difficult to do. But, finding the part may be. Blue Rhino, is the manufacturer for Endless Summer Patio Heaters, so start there.
May 19, 2011 | Endless Summer 2009 Open Flame Patio...
Repair services for endless summer patio heater in west los angelels/santa monica?
Your best bet, is to contact the manufacturer, Blue Rhino for possible service locations in your area.
800.762.1142 .
May 12, 2011 | Endless Summer (521050) Open Flame Patio...
Flame goes out after 5 to 10 min then have to wait until it cools to relight
Unless, it's the wind blowing the flame out, I'd say the Thermocouple needs to be replaced. This is based on what you said, " have to wait until it cools to relight." The reason for that, is that the burner control valve has to reset itself. You can also check the pilot and pilot orifice for obstructions. Blowing it out with a can of compressed air with a straw nozzle (like you clean your computer with) may also help solve the problem. As insects like to build nests in these heaters, when they are not in use.
Endless Summer Patio Heaters are manufactured by Blue Rhino under the name Uniflame and Endless Summer. You can purchase any necessary parts from them online, if necessary.
Hope this helps you to solve your problem.
Mar 23, 2011 | Endless Summer 233010 Natural Gas...
I have an endless summer patio heater the pilot lights but the does not stay on when you turn the knob to start the heater. Got it on once but then the flame blew out and could not start again
You need to replace the Thermocouple. Endless Summer Patio Heaters are manufactured by Uniflame, which is owned by Blue Rhino. You can order the Thermocouple direct ly from either company. Just make sure you have your Model Number handy.
Mar 06, 2011 | Endless Summer 2009 Open Flame Patio...
The pilot goes on but when i un-depress the gas knob to turn the burners on it goes out..hence no flame. what's teh problem?
Generally this is caused bu a worn thermocouple, these last form 2 years up to 6 years but will wear out at some point. For help see patio heater problem solving, these patio heater specialist have helped me in the past.
Mar 03, 2011 | Endless Summer Blue Rhino 235000...
I have an Endless Summer patio heater. I have only used one 91) 20# LP gas tank and now afetr replacing the tank the pilot won't stay lite. I have call blue Rhino and they said it is the thermal...
I would have suggested the same thing. It may not be cleaning it needs. If the thermocouple has failed, then it needs to be replaced. I sure would start by giving it all a good cleaning though.
Farmerbear at FixYa.com
Sep 21, 2010 | Endless Summer Blue Rhino 235000...
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Sep 02, 2010 | Endless Summer 153100 Open Flame Patio...
Pilot assembly parts or thermocouples
Hardware store thermocouples don't work on patio heaters. The fittings are not the same thread and they are not set up for the anti tilt safety switch. You'll need to purchase the parts from Blue Rhino.
Jan 29, 2010 | Endless Summer 233000 Open Flame Patio...
Blue rhino endless summer patio heater
Try replacing the regulator, easy fix. If it is not the regulator, the thermocouple could be bad, or the pilot flame may not be strong enough to heat the thermocouple. Take apart the head, if you are comfortable with it, and see if there is a blockage in the pilot assembly.
Jun 28, 2009 | Blue Rhino Portable Patio Heater
Outdoor patio heater won't stay lit
I'm told by Charmglow that the problem is the Thermocouple. iHowever,it took me several calls to get someone to admit this. They are sending a new thermocoupler. My heater is less than a year old and under warranty--but it's a shame things like this happen.
Originally I was told it could'nt be the thermocoupler as they normally last at least 5 years.
Try it--as it may solve your problem as well.
Sep 21, 2008 | Heating & Cooling
Endless Summer 2009 Open Flame Patio Heater Logo
250 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
