Question about Char-Broil Commercial Stainless Steel Grill
I replaced the burners, part #80018594, in my Commercial series grill. Do I need to adjust them?
    Brigadier General:
  • 4,736 Answers
Normally, I would say know, if they are exact replacements. However, the only way to know is after you light the burners and check the flame colors and heights. For propane gas burners, the screw on each burner should be all the way in. For Natural Gas, about 2/3rd's of the way in.
If you tank has bee turned OFF during repair. Open the tank valve VERY, VERY SLOWLY aSlow Motion, slow) until the valve is fully open. Then light the burner farthest from the tank first and turn it to high. Does the flame height and color look correct? If so, light the remaining burners the same way. Do all the flame heights and colors look correct? If so, you're ready to start grilling with your new burners.
If not, turn the burners OFF and Let them cool completely, before making any adjustments.
Hope this helped you. Please let me know and Happy grilling!!
Posted on May 28, 2011
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
Why my Grill does not heat up to 400 ?
Do this..... turn on just one burner. Once the one burner is lit, turn on a second burner. If the flame in the first burner gets lower, you most likely need to replace your regulator.
Nov 22, 2009 | Char-Broil Commercial Stainless Steel...
SEVERAL DAYS AGO,THE GRILL GREASE CAUGHT FIRE,TEMP WAS 600,TURNED OFF IMM.SINCE THEN GRILL LIGHTS,FLAME IS VERY LOW OTHER BURNERS LIGHT BUT FLAMEIS LOW. HAVE CHECKED GAS SUPPLY.EVEN PUT ON A NEW TANK.SAME...
The regulator is damaged. This is the little round between the hose connected to your knob adjustment and the Gas tank. This one is not expensive. it costs less than 30 bucks. Good Luck.
Jul 06, 2009 | Grilling
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
Char Broil Commercial Series
What you are expierencing is a restriction in either the line coming from the regulator or a bad regulator. Most likely I would lean towards the regulator.
Jun 11, 2008 | Grilling
Char-Broil Commercial Stainless Steel Grill Logo
599 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
