Question about Hunter Ceiling Fan Light Switch Control
Hunter Fan model no.22570
I purchased a brand new Hunter Ceiling fan and after wiring it up,the light comes on but the fan does not. Could it be a bad motor? I've wired it up as per the instructions and it just won't run.
  • Anonymous Jan 20, 2009
    I have the same fan and the same problem.
  • 3,640 Answers
Take it back, and explain to them it will not work. you should be able to get a new one !!
Posted on Dec 17, 2010
I have a Hunter ceiling fan with a remote control model number 85095. The remote will turn the fan on and off and change the speeds but it will not turn the light on or off anymore. Any help?
Make sure the wires to the light kit are connected to the light & light wire connected in ceiling.If that's not your problem then you probably need a new receiver. Call 1-888-830-1326 and have your FAN model handy.Should be a five digit number beginning with a 2.
Jan 14, 2013 | Hunter Ceiling Fan Remote Transmitter...
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
Fan works fine, lights don't. Could it be the remote?
Had this happen to me and it was a hunter fan. Similar problem. Fan worked,lights went out. Took light bulbs out, lowered the light fixture. Tested power coming from the ceiling to the quick connect pins for lights. The power was good. So the Problem's in the light kit. Turns out the government requires all new fans to have certain wattage to lights, set at 190. So 3 60w bulbs or 4 40w. Inside the light kit is a limitor hooked to the black power wire coming from the quick connect,It is smaller wire and mine was pink into limitor and white coming out. Not very big. This went bad so i called Hunter, sending new light kit, but I just wired straight black to black wire bypassed that limitor and lights work fine
Aug 29, 2012 | Hampton Bay 24750 Huntington III Ceiling...
Hunter ceiling fan model 23530-300
the roll was rusted maybe .you can take apart it for checking .
ceiling light
May 01, 2012 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Jan 28, 2012 | Hunter Ceiling Fans Individual...
Fan will not work, but light will. it is model # 21871a-420. the remote will not work either function. there is power at the box. i purchased a new Hunter universal remote model # 27227 and the wiring is...
You have to get the correct receiver for that fan. There's no such thing as a universal remote,no matter what it says on the box. Call 1-888-830-1326 and you can order your correct part.
Sep 04, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Order capacitors for Hunter fanscapacitors Where
you can call hunter technical support. the number is-- 1-888-830-1326, they should be able to help! have a good day !
Jun 03, 2011 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Hunter Ceiling Fans
Unfortunatly that is a common thing with most manufactorers now a days! they are not in the service industry. make it, sell it, dump it, make a new one. and the cycle goes on and on. You may be able to find a repair person who can fix the fans for you at a reasonable cost.
Jan 18, 2008 | Oasis Hunter 54' Ceiling Fan
Dryers Logo
225 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
