I changed my my password and used it one time. Now when I enter that same password I get the message that the password is not right
  • 543 Answers
You see to capslock and numlock, and language, if there are right and your message will be, reset router., then log in by standart login password.
Posted on May 28, 2011
Hello there,
At first, check if caps lock is turned on/off.
If you forgot password, or you can't log in, reset your router, by holding reset button on it, for a few seconds.
After that, you router user name is ''admin'', and password is either ''admin'', or ''password''.
When you log in, set up your router data as you wish.
Sincerelly,
Steve TM
I changed the admin password on my sentient cctv dvr from the default 123456. I saved the changes but now get the message incorrect password when I input the six digit password I stored. Please help
Hello
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
May 22, 2011 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
Hi. i lost my password of my Projector Benq MP610, with code 22504-15078-7347-9687. i'm looking ford to your help.
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting->Change Password 2. Press Left or Right (button). A "Password Change" message displays. 3. Enter the old password. i.If the password is correct, you can go on to enter new password.
IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __
ii.If the password is incorrect, a "Password Error" message displays. Press Up to try again or press Down to cancel. 4. Check the new password. i.Pressing Auto completes the procedure. ii.Press Up to try again. iii.Press Down to cancel the set-up and return to the on-screen menu.
Mar 10, 2011 | BenQ MP610 Multimedia Projector
How change password in yahoomail
Changing Yahoo Password:
Here is the way, through which you can easily change your existing Yahoo password.
Login to yahoo through www.yahoomail.com
Click on you account name it will populate a menu, then click on "Edit My Account".
System will asks you to re-enter your current password. (For security reasons and to authenticate user validity).
After success, you will see your Yahoo account information. Locate for "Change Password" link and click it.
Enter your current password and then enter your new password two times in the given related fields. Click Save button.
System will prompt you the message text as "You have successfully chosen a new Password". Asshown...!
Jan 24, 2011 | Yahoo Messenger
Want to change the time
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316. The 4 top line/feature keys are now used for programming.
the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Nov 08, 2010 | NorStar T7316E Corded Phone
Trying to set the time on the phone but i dont know the password
Try feature **8463 (time) or feature **266344 (config). Either way, changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 8 4 6 3" or "* * 2 6 6 3 4 4"
7.- Select AM or PM
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
16.- Enter month
19.- Enter day
Aug 16, 2010 | Nortel T7316E 2-Line Corded Phone
My message recieved time is displayed wrong
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
THANKS
Jun 21, 2010 | Nokia 7210
My startalk flash answering messages are messed up and not playing at the right times, i cant access the startalk admin to change it.
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
If you have 3 digit intercom #s then the password is 1020000.
Apr 27, 2010 | NorStar Startalk Flash 2 Phone
How can i cchange my password i also forget my privacy
login to your email on yahoo and go to options right side top on your screen then click on more options, click accounts on the left side then a window appear which is add or edit account click on that, then a new window appear on that window click on the account information, this will ask your yahoo password, enter your password there, then you can see under sign in and security first row there is change your password link click on that, now change password window appear enter your old password there and in 2nd row enter your new password which you want to make for your email confirm your password by enter one more time ,, then save
your password is stored now
Regards
manish
Mar 22, 2010 | Yahoo Messenger
I have a BenQ Projector MP610. I lost my password and now i cannot use my projector. I get the code: 22504 13898 6789 8507. Please help...Please email me the decoded password... vmonacillo@yahoo.com
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power) and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right4 for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting > Change Password. 2. Press Left 3 or Right4. A “Password Change” message displays. 3. Enter the old password. i. If the password is correct, you can go on to enter new password. IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __ Keep this manual in a safe place. ii. If the password is incorrect, a “Password Error” message displays. Press Up 5 to try again or press Down 6 to cancel. Password Setup Enter Password Press Auto to Confirm Press 5 or 6 to change number Press 3 or 4to move 0 0 0 0 Password Setup Do you want to use 0 0 0 0 as your password? Yes Auto No 5 Cancel
Feb 17, 2010 | BenQ MP610 Multimedia Projector
Can't change the time on my Panasonic KX-T7433 phone
While the handset is still on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press program to exit program mode and you are done.
Please rate this answer if it was helpfull.
Thank you.
Jun 24, 2009 | Panasonic KX-T7730 Corded Phone
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
