How to replace the heater core for my Mercedes Benz 1989 190E 2.6
emissionwiz
  • 76682 Answers
SOURCE: heater core replacement
This is a really easy job, disconnect the heater hoses at the firewall, go inside the truck on the passenger side there is a plastic panel/cover over the core, 6 bolts/screws I think, remove the cover pull the core, tops 1 hour, as job at work I did them in 20 minutes.
Posted on Oct 15, 2008
SOURCE: Replace Cabin Filter in my 2002 C240 Mercedes Benz
I have a 2002 C240 Mercedes and need to replace the cabin air filter. Problem, I don't know were it is located or how to replace it. Can you help me.
Posted on Mar 21, 2009
lastech
  • 408 Answers
SOURCE: how do you remove the center console in a 1982 Mercedes benz 380S
hi,center console or center gear lever cover(wooden console)
  • remove radio,then remove control unit of aircon by pressing down the 2 latch,located in upper edge in radio hole.remove screw in upper part of console
  • remove black cover (look like astray)fold both side,remove screw
  • remove shifting lever
  • try to lift in the console,be careful,sometimes sticky
Posted on Mar 22, 2009
  • 11 Answers
SOURCE: replacing the battery in a 2001 mercedes benz
Battery base has a device that clamps the battery on a step/notch on the side. Use a ratchet with an extension to loosen. Once it is loose you can remove the battery.
Posted on Apr 03, 2009
  • 43 Answers
SOURCE: How to replace air filter in a Mercedes benz 2005
Hi, The air filter is located under the engine cover. Just lift off the cover and access the 20mm torx bolts under the cover.
Posted on Apr 06, 2009
I have no heat. I only get cold air. Any suggestions?
check that the heater controls are turning on the coolant tap for the heater core
check the heater core is not blocked
Jan 14, 2016 | 2006 Mercedes-Benz Mercedes Benz CLS500
Why must i discharge the air conditioning refridgerant prior to removal of the heater core on a 2003 c230 mercedes 1.8l coupe.
The reason in why you must evacuate the a/c system with an a/c machine before you can remove the heater core is because the evaporator is located inside of the heater core box assembly. So before the heater core box assembly can be removed the a/c system must be evacuated then you can disconnect the a/c lines that go through the firewall to the evaporator.
Jul 01, 2015 | 2004 Mercedes-Benz C230 Kompressor
My heater comes on but only blows cald air
sounds like you have ablooked heater core. start up the car let it warm up check your heater hoses both of them should be hot if not you have a blockage . take both hoses off and back flush them
Oct 12, 2013 | 2006 Mercedes-Benz Mercedes Benz CLS500
Why is gray smoke coming from the top of my dashboard vents when i turn my heater on in my 89 ford f-150 truck?
Are you sure its smoke not steam? Most common problem is the heater core leaking. Look for moisture on the floor boards first. If it is wet then you have a heater core problem
Mar 07, 2013 | 1987 Mercedes-Benz Mercedes Benz 190 Class
My 2006 e350 mercedes heater dont get warm
Could be thermostat, Heater Core, or variouse other issues, could use more info, smells, noises, visuals, ect.
Jan 08, 2013 | Mercedes E-class Pillar Posts Trim Set
My Mercedes is dripping underneath passenger side with a watery substance what do you think this may be
This in side the car? If so it would be your heater core it leaking sorry iv;e never done one on a mercedes all i can tell you is some heater core easy to replace and some are a major job where the entire dash needs to be disambled to get at it hope yours is one ofthe easy ones
Nov 16, 2010 | Mercedes-Benz M-Class Cars & Trucks
I own a 1990 190e Mercedes-Benz, after it has run for a little while, it starts to leak water on the passengers side, behind the heater, which leads to the car over-heating. How could I fix this?
This is your heater core leaking. One thing you can try is some of the stop leaks that the auto part stores sell. I would try "Liquid glass" as the heads on these are kind of delicate once overheated. This may also stop any other damage occuring(like leaking headgaskets). The only other fix is replacing the heater core.
Mar 03, 2010 | 1990 Mercedes-Benz 190
Water is getting inside of car on passenger side. and i think it effected the radio and heating/cooling system.
The coolant hose going into the heater core gets leak at the clamp end. Need to replace this piece of hose. This sounds simple, but it is not uncomplicated. There are 2 hoses coming in and going out from the heater. You can make a loop to bypass the coolant going to the heater core to eliminate the leak. However, do this way you won't have the heater at all.
Oct 06, 2009 | 1995 Mercedes-Benz C-Class
Antifreeze under floor mats
What you Discribe is Indickitive of The HEATER CORE Leaking into the HEAT / EVAPERATOR BOX Adn Can be Corrected By Replacing the Heater Core. PLEASE Reply for Replacement Procedure. Hope this Helps
Jun 17, 2009 | 1993 Mercedes-Benz 190
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
