Question about Briggs & Stratton Garden
Have a Murray mower model 405000X8 riding mower. Starts fine and idles fine. Dies when I put it in gear or when I turn on the blade.
  • 14 Answers
SOURCE: murray riding mower dies when i release the clutch
could be the seat switch i had tht problem before i bypassed the switch and waalaaaa
Posted on Apr 27, 2009
  • 246 Answers
SOURCE: Murray Lawn Mower won't go in gear
Hello:
>>From your Description it Sounds like the Clutch Idler Pulley Bearing have Seized and the Idler Pulley cannot/is not Turning and the Squeal is the Belt Dragging Across the Pulley.
>>Just because there is No Smoke Does Not mean the Belt is Not Slipping.
>>I Suggest you Remove the Deck and Check All the Pulleys and Especially the Clutch Idler and Idler Arm Bracket.
>>You can View a Breakdown of this Mower At this Site Addy; http://www.smallenginepartswarehouse.com/parts.asp and Select Shop Online Parts Lookup. Select the Model Tab. Select the OEM and Enter the Model Numbers (). Now Double Click on your Model in the Results Area. Now Select Sectional View. Now Select the Section of the Mower you Wish to View.
>>If the Above Site Does Not have your Unit Listed; Let me Know. I hae 2 Other Sites that have Older and Newer Units Listed.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 130 Answers
SOURCE: Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
Posted on Jul 18, 2009
SOURCE: Riding mower having problems starting then runs roughly
I have a Scotts _ John Deere law mower tractor model S2048-S2554 Serial number 020-001, the engine runs but sounds like it is going to die or it needs air --- it runs unnevenly
Posted on Jul 20, 2009
mickey813
  • 472 Answers
SOURCE: murray riding mower the blades will not engage
sounds like the cabel it broke
Posted on Oct 01, 2009
I have a 17.5 Murray riding lawn mower engine runs well when I engage the blades it spits and sputters and starts backfiring what could be the problem
Sounds like bad fuel....runs fine when not under stress but poops out under pressure. Drain fuel and refill with new mix if it's a 50/50 gas-oil blend.
Apr 26, 2016 | Murray Garden
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
My landlords toro riding mower starts fine but as soon as i touch the shifter to put it in gear it dies over and over..carb is clean and new gas with stabilizer
There are several safety switches that prevent operation in case the rider falls off, etc. First check seat safety switch...the likely culprit. It must close ensuring a person is in the seat for movement or blade operation. Find a toro wiring diagram, or visually wire trace, or just inspect the proper operation of all safety switches. DO NOT BYPASS SAFETY SWITCHES, but ensure they are working properly for SAFE OPERATION.
Nov 20, 2013 | Toro Garden
Murray Select Model # 405000X8 trong vibration when I engage mower deck. Also can't keep deck even.
Could be a number of things included but not limited to.....blade spindle bearings....idle pulley or engager pulley......could also have a bad spot in belt....causing a vibration. This vibration could also lead to deck coming out of level as that model have a leveling adjustment on the deck level control lever.
Oct 22, 2013 | Briggs & Stratton Garden
I have a murray riding mower with twin blades..how to change
take a socket rench with 2 feet pipe....slide the rench handle to the pipe and that well give you enough power to turn you have to hold the blade with something from turning .....ometime you can hold it with a towel
Oct 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
my murray riding mower wont pull when i put in gear i dont have a clue what to do,it doesnt seem like its going in gear
May 15, 2009 | Garden
I have a 12 HP Murray riding mower about 6yrs old model 30577X8A. I am having trouble shifting it in and out of gears, ever thing runs just fine can you help?
Jul 04, 2008 | Computers & Internet
Garden Logo
243 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
