Question about Honda Black Max 2600 PSI Pressure Washer
My simoniz 2600 with the 5.5 honda won't run. There is a small amount of milky substance when I pour gas in the air intake. It will run for a few seconds and quit. I would like to know how to remove and clean the carb and where to buy carb kits or atleast the gaskets.
  • 212 Answers
SOURCE: 8 hp honda on cement mixer starts on first pull but shuts down as if it is running out of gas. I put fresh gas in it and cleaned the filter and bowl of the carb.
if it has a fuel filter. check that. change the spark plugs.
Posted on May 24, 2009
Editor925
  • 285 Answers
SOURCE: What gas and oil do I use on the Honda Excell 2600 pressure washr
That engine requires a separate gas and oil. There is an oil sump with oil level needle and cap on the side of the engine. This is where you fill it with special pressure washer pump oil available from any good outdoor store or place where pressure washers are sold. As for gas, Unleaded or Premium unleaded gas will work fine. Try not to use any fuel with ethanol blends however. Here is a list of oils that will give you an idea what to buy for the oil reservoir: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2Fs%3Fie%3DUTF8%26ref%255F%3Dnb%255Fss%255Fgw%26field-keywords%3Dpressure%2520washer%2520pump%2520oil%26url%3Dsearch-alias%253Daps&tag=onlinetoolrev-20&linkCode=ur2&camp=1789&creative=390957
Posted on Jun 15, 2009
electrotech1
  • 1126 Answers
SOURCE: Honda GX 240 on woodsplitter
Install a new plug, and make sure your gas mixture is not to rich, And you air cleaner is clean
Posted on Oct 16, 2010
  • 13 Answers
SOURCE: Have an excell 2500 honda
the carborater may need a dighafram or carborater cleaning of the bowl
Posted on Jan 19, 2011
  • 731 Answers
SOURCE: I have a Honda 5.5 hp pressure washer and it wont
try soaking the carb for 15 minutes in gasoline. If you have a plugged port just sparying may not be enough to clean it
Posted on Jan 20, 2011
Egr valve chevy lumina '97 3.1 lumina ,i pulled the egr there was a white greasey substance in it as well as well as the passages to the throttle body and and exhaust, what is it,where did it come...
that sounds as if your engine breather system requires cleaning, the substance is emulsified oil, normally caused by poor oil, lack of oil changes, or possibly head gasket problems, clean out all the breather hoses, filter etc, run engine until warm, drain engine oil and refill with a good quality oil, renew oil filter and then run and check again after a few miles
Oct 27, 2013 | Cars & Trucks
Honda Lawn mower, won't pull gas
hi
remove your center jet could be same one that holds your bowl tight under the bowl and look for a small plugged up hole clear it open,,,,,, and it should **** fuel up and start and remain running
joe
Oct 01, 2012 | Garden
My 1985 grand Marquis won't start I can pour gas
Take the gas filter off. Should be located near the front of the carbeurator, take off the air cleaner and look for it, it takes 2 wrenches to take it off, a little gas may spill out but not much and replace it, however there is a strong possibility that he gas pump is out if the filter is fine. Hope this helps
Jul 11, 2012 | Cars & Trucks
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
Why won't my truck stay running when I'm not
Try cleaning your throttle body. Over time on high mileage vehicles, the throttle body butterfly valve will gunk up with sludge, and dirt. This will prevent air from entering the intake manifold while the engine is idling, causing low idle/stalling. A can of throttle body/carb cleaner will do the job. First, remove the intake tube to get to the butterfly valve. Spray a small amount of throttle body cleaner directly into the intake, and wipe any excess fluid with a cloth. Also, inspect your air filter. I hope this helps
Matt
Jun 26, 2011 | 1998 Dodge Ram 1500 4WD
MY 2003 Toyota Echo ran out of gas and I put one gallon in and it won't start.
If it has a carburator. Take the air cleaner off and pour a very small amount of gas into the top of the carburator. Like about a teaspoon's worth. If its fuel injected I have no answer for you.
Jun 19, 2011 | 2003 Toyota ECHO
I HAVE TRIED ALL THE IDEAS REMOVE SPARK PLUG,INSERT SMALL AMOUNT OF GAS ETC. IT HAS GAS AND FIRE BUT NO START
if you say it has fire,then the small amount of gas you poured into the spark plug hole will fire if theres a spark,if it does fire when this is done its your carb thats fouled up,remove the air cleaner from the carb and when it fires,take WD-40 and spray it into the carb where you removed the air filter&cover and see if you can keep it running,also did you remove the sediment bowl off the bottom of the carb to see if and how much water/dirt is present in this bowl???
Mar 22, 2011 | Honda 25cc 4-cycle Mini Tiller
My car ran out of gas I put gas in it and now it qont start
we just had to replace the fuel pump in our 96 deville, The mechanic said that running the car with a low level of fuel can cause strain that would cause it to break,
Nov 28, 2010 | 1996 Cadillac DeVille
Gas in oil
You are right, something is letting the float stick and get gas into the oil. You should also probably check the valve lash after replacing the carb.
Carl
Apr 03, 2009 | Electrical Supplies
Honda Black Max 2600 PSI Pressure Washer Logo
66 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
