Question about Whirlpool LSR7333 Top Load Washer
I bought a whirlpool washer LSR7233E in 1997 what is the capacity? Back then it was labeled Heavy Duty Super Capacity Plus. I need to replace it so I want to know what is comparable today. Also, My Whirlpool dryer LGR4634eq0 is labeled Heavy Duty Extra Large Capacity. What capacity is that? Because I don't need to replace it and I don't want to buy a washer the will wash a load large than the dry will handle.
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
  • 1073 Answers
SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
Posted on Apr 12, 2008
tzweeb
  • 318 Answers
SOURCE: kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Heavy Duty 70 Series Extra
If this is a Kenmore Top Loader washing machine, it sounds like you have a broken motor coupling. The washer filling and draining, but no agitation and spin are common symptoms with this problem. There may also be a rattling or whirring sound as the drive motor attempts to engage.
NOTE: If the washer drains, the drive motor is working. This drain pump on this washer is driven by the drive motor.
The motor coupling is located between the back side of the drive motor and the gearcase (transmission). The coupling is used in place of a drive belt, which is why this type of washer is referred to as a "direct drive". The following link explains how to access and replace the motor coupling:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The part number is included with the link and can be purchased at appliancepartspros.com for about $11. I have included an illustration of what the coupler looks like below.
If the motor coupling is intact upon inspection, the other source of no agitation and spin would be the gearcase. The gearcase on these washers is fairly simple to replace. If you narrow it down to a failed gearcase, the next link explains the steps for replacing one:
http://www.fixya.com/support/r699497-replacing_gearcase
I could only find your model number referenced at repairclinic.com. The gearcase on their site lists for about $160 and is listed as item 423.
I could not find any exploded view diagrams of your washer, but the majority of all Kenmore and Whirlpool top loaders are designed with the same direct drive system. You can purchase a Direct-Drive Repair Manual at repairclinic.com for about $20 (Item number 1170635) if you need a guide for reference.
If you have any questions about this repair, or require additional assistance, please let me know. I hope I've given you enough to work with in trying to narrow down the cause of your problem.
Posted on Sep 29, 2009
mgprice
  • 744 Answers
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 14, 2009
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Whirlpool heavy duty super capacity plus washer will not agitate or spin. I replaced the agitator dogs but still have the same problem, is this a transmission issue?
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
Jan 22, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool LSR7333 Top Load Washer Logo
404 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
